Question about Sony EVO-250 Hi8 VCR
Sony evo 9720 needs a new circuit board - Sony EVO-250 Hi8 VCR
Unlock a Blackberry 9720 phone when it cant get a signal
Signal is not required to unlock a Blackberry 9720. All you need is a non accepted SIM card. Once you enter a non accepted SIM card in your Blackberry 9720, it would prompt you to enter an unlock code. You can get the accurate unlock code for a Blackberry 9720 from SuperUnlockCodes.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Blackberry 9720 with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9720 should then be unlocked.
Oct 17, 2014 | Blackberry 9720 Unlocked GSM OS 7.1 Cell...
My bb 9720 key pad not working
In almost all cases, this is due to a blown IC on the main board. Take your phone to your retailer if it still has a warrantee or to a reputable repair shop if it is out of warrantee.
Aug 16, 2014 | Blackberry 9720 3G, 5MP, OS 7.1, Qwerty...
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Mar 11, 2011 | HP Compaq Evo n610c Notebook
Sony EVO 9850 Hi-8 editing deck is show an "Error 90" message. What is the problem?
Error 90 is a communication error between the SY board and the KY board. Possible loose cable or bad electrolytic capacitor(s).
Dec 07, 2009 | Sony EVO-9800A Hi8 VCR
Wiring diagram need for an Smoothfitness EVO treadmill.
Solved this problem by contacting the Evo/Smooth directly. Great service.
Oct 19, 2009 | Exercise & Fitness
I accidently connected a 28volt charger to my evo
if the battery charger powers the computer, then i would imagine the motherboard is fine...
there should be some kind of fuse insode the battery to prevent things like this from causing them to explode.
Replace the battery
Oct 11, 2009 | HP Compaq Evo Notebook N600c
I have a sony evo n600c and when it starts up its says 103 charge circuit fails does and the battary does not work i know i will need another battery but what i am asking is is the 103 charge circuit fails...
This error is commonly seen in Compaq laptops. Take out the battery,start the laptop with the adapter only and see if that error message pops up again and if not then it might be your battery.Usually battery life is 3yrs. Put the battery back again and see if the message pops up again. Try the battery on a different laptop. It could be the Voltage Converter Board...see service manual for the same or call Compaq service centre.
Jul 28, 2009 | Compaq Evo N600c Notebook
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Sony EVO-250 Hi8 VCR Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
