Question about Maytag Neptune MCG8000AW Gas Dryer
My Neptune MCG8000AWW Dryer isnt heating up. How do I get to the ignitor??? Does the front come off or is it through the back of the unit.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Where is the ignitor located in the maytag mcg8000aww
inside the burner funnel tube at the bottom of the dryer below the drum,you need to remove the front panel to access the ignitor
Aug 26, 2012 | Maytag Neptune MCG8000AW Gas Dryer
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MCG8000AWW no heat. I can see the ignitor glowing
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 16, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Gas dryer neptun DC does not heat and dry cloths
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 04, 2010 | Dryers
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
The gas was turned off for a 24 hour period neptune mdg4000
Here's a stab in the dark at your problem:
You moved your dryer to paint or re-do flooring. Handled the dryer a bit rough, so the ignitor broke. (they are fragile, especially after they have been used awhile) You may be able to confirm this by tipping the dryer from side to side or front to back a few times (easy, not violently) to see if you hear anything rattle in the bottom of the dryer. That rattle would be a part of the broken ignitor. (it still might not rattle, but the ignitor is the most likely suspect)
Jan 26, 2010 | Maytag MDG4000 Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag Neptune MCG8000AW Gas Dryer Logo
283 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
