Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
My Fridge is running Hot on the freezer side and the temperature is rising. Ice cream is melting etc. Fridge side seems OK but also not really cold. Which of the the settings on the internal dials 1 to 9 is for cooling, des 9 mean maximium cooling. Dials seem ambiguous. Thanks.
  • 86 Answers
It sounds like the condenser is dirty. It's under the refrigerator.
This is easy to do. Just get all the dust out of the condenser and things should start cooling down.
I hope this helps. Please leave feedback.
Thank You.
Posted on Aug 24, 2010
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
I have a Frigidaire upright LFFU1465 and it is on but not blowing cold air.
If the condenser is clean and the temperature rising, the freezer is short of gas
Apr 13, 2012 | Freezers
Fridge and freezer doesnt seem cold enough. Things are cool but not cold. Ice cream is not as hard as usual (soft but not melted). Ice maker not making ice. Adjusting thermostat doesn't seem to make a...
Please check the timer the thermostat and the heater for the auto defrosting to work. Switch off the fridge and after all the frost has gone off switch on to see if the sooling returns . If so you can be sure that the timerr does not work and so reduces cooling on frosting. If there is still no cooling then you will need to check onthe compressor and the gas pressure. Get help to confirm and take an estimate before attempting, get an warranty assurance for work. Hope you try out and see first.Good day
Aug 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Jul 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not working
the symptoms you describe, freezer temperature rising while the fresh food section "seemed" ok, my guess is by the time you read my response, the fresh food side will be just as warm as the freezer. when the cooling pattern is similar to this, it has to do with the compressor no longer running. the compressor itself may be ok, instead the starter has failed, but i would not recommend you even attempt this yourself, as you can cause permanent damage to your compressor, property damage to your home, or electrocution hazards to your self. I would highly recommend you have a reliable refrigerator repair service at least inspect it for you.
Apr 02, 2010 | Amana ARS2464B Side by Side Refrigerator
Not as cold as it should be
see if there is ice on the back wall of freezer if so this is an automatic defrost problem timer heater or limit switch
Apr 17, 2009 | Whirlpool ED5SHAXM Side by Side...
Not cooling but everything seems to be on
remove back panel inside freezer and evaporator pipework will be exposed.
if this is heavily iced up, airflow will be impeded and hence rise in temperature
disconnect from mains and melt ice off carefully with a hairdryer then switch back on
you probably have a fault with the defrost system if this is the case - get back to me
Jul 15, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
