Question about Dometic Rooftop RV Air Conditioner
The blower on my Dometic Rooftop AC shuts off then the RV reaches the set tempature but the compressor keeps running. It even runs when the therostat is in the off position. It will only shut off when the breaker is turned off. Can you help? If so, can the problem be fixed by myself?
  • richard_k521 Aug 24, 2010
    Thanks, I'll give it a try.
  • 6,927 Answers
There is a wire that is wired to the wrong unit,the thermostat wire needs to go to the compressor,so it will cycle,and the wire that is going to the compressor needs to go to the blower.
Posted on Aug 25, 2010
  • 11,800 Answers
The compressor is powered by the control board thru a relay. If it doesn't shut down it's because the relay is still activated.
You need to find out why: either the relay is stuck shut (replace it) or the command is constantly on (something is wrong with the thermostat or the connections from the board).
To find out which you need to open the unit, identify the circuits and test the parts - all you need is a basic multimeter and at least basic knowledge of electric systems. If you have it then yes, you can do it.
Posted on Aug 24, 2010
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
Why does my dometic ac runs but no cold air?
If the compressor is running, then you have a refrigerant leak. The blower fan can operate and make noise, move air, etc. So make sure the compressor is working too.
Jul 18, 2014 | Dometic Rooftop RV Air Conditioner
Duo-Therm ac when the temerture is reached the fan will shut off but the compressor stays running
Sounds like you hit it on the head--compressor should turn off when unit reaches the preset temperature.
Jun 10, 2012 | Dometic Rooftop RV Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Compressor won't shut off
you have a faulty capacitor you need to replace
Jun 05, 2009 | Dometic Rooftop RV Air Conditioner
Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Jun 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
93 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
