We have windows XP desk top. Can't install the drivers for the DWA-111 but the router works fine.
    Novelist:
  • 173 Answers
What specific error message/s does your computer prompt when you trying to install the wireless USB adapter? Since your running Windows XP you can skip on "run the CD first", try uninstalling all the componets for the adapter then restart the computer, when the computer is booted up properly insert the USB adapter(preferably used the USB port on the back of your desktop for maximum power). When the found new hardware wizard pops up, choose install software automatically(make sure that the setup CD for the USB adapter is already loaded on the CD-ROM drive then hit next.
If the installation proceeds click on finish a bubble should appear on the lower right hand side of your dekstop screen(syatem tray) prompting you that one or more wireless network is being detected, click the baloon and check if your network will show up on the list.
Posted on May 05, 2008
Wireless internet limited connectivity
The first thing to do is reset the router. There is a button on the router that you press with a paper clip.You will then have to access the router with your browser and a cat5 cable connection to change all the settings that you might need to change for security. DHCP should be enabled and there should not be an issue with the number of concurrent connections.
Feb 28, 2014 | Computers & Internet
Dlink dwa-110 drivers for xp
Here it is d-link dwa-110 drivers for windows xp. The file size is 9.6 mb, and zip format. You'll need winzip or winrar to unzip the drivers.
Good luck.
Thanks for using FixYa.
Jun 18, 2010 | D-Link DWA-110 54 Mbps WiFi USB Adapter...
I want to uninstall DWA-642 from my computer in anyway and it doesn't want to uninstall. I went to Control Panel, Ad Remove Programs and click Remove but it did not want to remove.. In the mean time after...
Have you tried Advanced system care,this link is for xp.
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=mncol
this program has an uninstaller program that works very well,install it then click Utilities button,look for the three tabs to the right.Click on Admin Tools tab.
The uninstaller program is listed as Iobit Uninstaller not only will it remove that program it will remove any residual folders.Hope this helps,don't for get to rate....
Jun 08, 2010 | D-Link Platinum RangeBooster N DWA-642...
I recently purchased this. (http://www.newegg.com/Product/Product.aspx?Item=N82E16833127272) and a copy of Windows 7 64-bit OEM. So, I go to install the utility and drivers and after the point where it...
Did you try these drivers for DWA-125?
ftp://ftp.dlink.com/Wireless/dwa125/Drivers/dwa125_drivers_120.zip
If your model is DWA-125 RevA2 then you need these drivers for it.
ftp://ftp.dlink.com/Wireless/dwa125_revA2/Drivers/dwa125_revA2_drivers_130.zip
Uninstall all the previous drivers/ apps related to your adapter. Download the appropriate drivers above. Unzip/ extract the file. But don't run any installer yet.
Plug in your adapter first cancel the windows new hardware found pop up if it come up. If windows says no drivers found thats ok. If windows finds the drivers and installs it right then great if not then lets move on.
Open device manager. Click on the adapter and click upgrade driver and select find drivers manually. Point it to the folder you unzipped all the files too. And windows should install the drivers this time.
Let us know how it goes..
Apr 02, 2010 | D-Link DWA-125 Wireless 150 USB Adapter...
Can I use drivers for dwa-11o in dwa-111?
This should be the one;
http://ftp.dlink.ru/pub/Wireless/DWA-110/Drivers/
The one below the parent directory.
If it's helped, please write a little testimonial.
Regards
Zahc
Feb 09, 2010 | D-Link DWA-110 54 Mbps WiFi USB Adapter...
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
DWA-643 installed but unable to access any wireless point
check the status of the device under Device Manager first and see if it was properly installed. If yes, you may use the wireless zero configuration utility built-in to XP or Vista. If your OS is lower than XP you have the use the utility provided by D-link. It usually comes with a CD installer for its driver and utility.
Please rate and see if it helps. Thanks and goodluck.
Oct 10, 2008 | D-Link DWA-643 Wireless Adapter
I've just purchased DKT-110 wireless G starter kit.
The Internet/WAN port on the router should be connected to your cable modem's internet port.
Then on your laptop, you should click on "View available wirless networks", your Router should show up there. click connect and you should be able to surf.
Note::The USB DWA 111 should be connected to your laptop and the drivers installed
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Dwa-142
It wil work in vista..
Vista drivers here..pick the latest v 1.30
ftp://ftp.dlink.com/Wireless/dwa142/Drivers
Sep 23, 2007 | D-Link RangeBooster N DWA-142 (1010125954)...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
