Question about Whirlpool Dryers
I have a whirlpool gas dryer model LGQ9508PW0. It is not drying. I noticed that it would egnited the firest time but not after that. I replaced the egniter thing it was worn. Now WITH NOTHING IN IT it I watched it cycle on and of 6 to 7 times. When I place clothing in it will cycle only the first time. When the egniter comes on the gas valve does not turn on. What could be wrong?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
The dryer heats up for a short time then cools down after about 1 minute. How do i repair? This is a Whirlpool LGQ9508PW0
From what you are saying you need to replace the gas valve coils.You need to remove the front to access them.They are on top of the gas valve.
Jul 24, 2010 | Whirlpool LGQ9858P Gas Dryer
Dryer stop heating
Try vacuuming out the intake and exhaust vents for the burner. Lint collected there can block the burner operation. Hope this helps!
Jun 28, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer takes hours to dry
sound like you dry not heating,might need to replace the element
Apr 24, 2010 | Whirlpool GGW9250PL Gas Dryer
I have a whirlpool dryer which no longer dries my clothes. I replace the sensor, but now I notice that while the gas does ignite initially in the dryer, after 5 minutes it does not. The ignitor in the...
The problem is the dryer coils are failing. They tend to fail when they heat up. These parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles
Apr 01, 2010 | Whirlpool Dryers
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Taking apart Whirlpool dryer
below the door the panel is held onto the frame with clips. Use a putty knife to get it out yer way.77d0e23.jpg
GAS DRYER INFO
Mar 02, 2009 | Whirlpool LGB6300 Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Dryers Logo
152 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
