We had a service technician come out and work on our a/c unit yesterday. He replaced the fan motor (only 2 years old) and insisyed that the fan blade needed cleaning. Next, he said we needed freon, but that the company policy stated that they would not add freon to a unit without first cleaning the coils ($188 for the cleaning). We have never had a technician tell us this before. Sounds like a way to make more $. Can you confirm if cleaning the outside coils is absolutely necessary before adding freon?
  • 407 Answers
In short, yes, you have to have the outside coils clean before adding refrigerant so that you can correctly charge the unit. Dirty condenser coils will cause a rise in pressure inside the system because it cannot condense the refrigerant correctly. On the other hand, unless your coils are corroded or completely clogged with a abnormal substance, most people wash out their own condenser coils with a water hose. You just start at the top and work your way down with a left to right motion, being careful not to bend any of the aluminum fins, which usually takes quite a bit of pressure. All you need is to make sure that your coils are able to have air pass through them freely. When they say they are going to clean the coils, they actually use a chemical substance that they spray on and rinse off and if you can avoid it, you can save that ridiculous fee! Hope this clears some things up and good luck!
Posted on Aug 25, 2010
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
FAN DOES NOT GO ON AND CAN THE FAN MOTOR JUST BE CHANGED WITHOUT REPLACING THE COMPLETE UNIT ??
Yes and maybe.
If you open unit, usually fan motor is plugged in, and motor is removable with bolts.
The problem is finding new fan that fits same housing without spot-welding and drilling.
I did google image search for "replacement vent fan motors" and results show choices.
For example Nutone:
http://nutoneproducts.typepad.com/nutone-products/nutone-bath-fans/page/2/
If you can locate same brand vent at local box store, you can use parts from new one to repair old one without project of replacing fan housing.
20 years ago, motors went to electric repair shop and they rewound the motor.
But today, motors are landfilled or shipped overseas for recycling.
All costs are energy, and right now, cost of re-wind is more than buying new motor, or new vent.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Panasonic WhisperCeiling Bathroom Fan...
I have a 25 year old aicondition unit. Yesterday the fan on the outdoor unit stop working. I checked the fuses and found one blown I replaced the fuse but the fan did not come on. Is there a delay timer?...
Your problem could be several things. It is hard to say without looking at it, but here are some things you can check. First try turning the fan by hand and see if it spins freely. Check the fan capacitor. Check the contactor which will also cause the compressor not to run. The fan motor could be burnt out. There are plenty of things to check. Also you have a 25 year old unit which means its probably close to the end of it's usefulness.
Aug 10, 2010 | Carrier Heating & Cooling
Furnace unit to be louder now than last season
Check your air filter, make sure all registers are open full and there is no restriction in all ducts. Could be an unbalanced fan, clean the squirll cage fan with a brush and vacuum.
Jan 09, 2010 | Heating & Cooling
Have 2 year old Frigidaire FAH105N1T Air Conditioner. Fan stopped working on fan or cool. Serviced twice and they said fan needed to be oiled. Worked 3 weeks then they said it needed fan motor. Bought new...
it possible to replace the defective as follow:
1- take out the unit
2- remove the top cover
3- try to take out the wires from there connections and note each color to witch connection
4- loose bolt of indoor blower to the shaft
5- open the bolt of the condenser fan to the other end of motor shaft and take out the fan
6- open the fixation nuts or bolts of the motor then slide it outside.
7 replace as take care about witch side of shaft is for blower or fan.
Sep 06, 2009 | Heating & Cooling
Home heating system question
Hello meglong what type of trane model is it? In the service package that was offered to you was one removing the exhaust fan for cleaning and a minor tune up every year? Because normaly the exhuast fans can be cleaned just by blowing out the fan with some air or even a vaccum cleaner.
Oct 29, 2008 | Heating & Cooling
Weather king central air conditioner
You have done a good job under the circumstances. It could be a bad start/run capacitor as well. It carries a lot of amperage so I suggest hiring a technician to check the capacitor and the motor.
Jun 25, 2008 | Heating & Cooling
Iced up Samsung RS21 JGNS Help!!
Defrost the unit and after defrosting, with the unit unplug rotate the fan blade manually using your finger. The fan should rotate freely, the blade should not touch the fan frame. Slow rotation of fan motor can cause icing. Worn out bearing, misalign fan blade, partially burn fan motor can slow the rotation of blower motor.But if the blower operate normally, then the unit may be under charge of refrigerant. Qualified technician is needed with this problem.
Mar 05, 2008 | Refrigerators
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
