Question about Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri
Trying to remove shower handlewith no set screw on handle
How to remove handle on single handle grohe shower valve. no screws on handle
There should be set screw on bottom of handle it very small it's a Allen wrench set screw
Jun 12, 2016 | Grohe Home
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
My set screw will not backout in order to remove handle for cartridge repair. Screw turns counterclockwise but will not unseat. How can I remove for repair?
Try some lime remover on the screw/handle, and make sure you are using the correct tool and that it is actually turning the screw. Some are allen wrench style while others are slotted screws. If you are sure you are using the correct tool and it is loose, try to pry under the handle or get a handle puller tool. If you could post a picture of the handle I might have a more specific answer.
Mar 24, 2013 | Moen & One Handle Tub & Shower Faucet
Bannockburn handle removal
lots of these types of handles have a very small allen wrench set screw somewhere under the handle or on the side...loosen set screw and pull off...good luck
Sep 22, 2012 | Danze & Single Handle Tub And Shower...
The shower handle seems loos and to far from the hot/cold plate
remove the set screw, put the handle all the way on the valve stem, and then replace the set screw.
Jul 09, 2011 | Moen T3112BN Brushed Nickel Kingsley...
We want to remove the shower unit. its a single handle unit. how to remove from the front? there is no screw holding the handle.
Look on the bottom side of handle and see if there is a allen head set screw. Loosen screw and you should be able to remove the handle, Thank you.
Nov 22, 2010 | Peerless Industries Peerless& Single...
I have a one handle Delta shower knob. I have turned up the hot water heater. All the other sinks within a few feet of the shower run very very hot but my shower stays a mild luke no matter what. The knob...
On your single handle the first thing you do is remove the handle. To do this locate allen set screw on handle and select the right size allen wrench to fit it. Loosen set screw and pull handle out away from wall to remove it. There should be a plastic disc on the handle stem, slid it out to remove it.Remove chrome sleeve..On valve body there are marking that show hot or cold settings. Seperate teeth on geared flanges and rotate set stop toward h mark on valve body. Each tooth will change temperature about three degrees. Make trial setting and reassemble and try it out. If you want it hotter just repeat adjustments. If you try to go to far you will not be able to mesh gears,simply back off alittle bit and try again.Hope this helps you. Thanks
Nov 22, 2010 | Delta & Single Handle Shower Faucet
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
How do I remove the single faucet handle to replace it.
There is a set screw in the handle, it can either be a hex screw or it can be a philips head screw depending on which faucet you have. If you have a clear decrative handle then there is a cap that you remove and the screw is behind it. Once you remove it you can remove the other trim.
Mar 22, 2009 | Moen & One Handle Tub & Shower Faucet
Price Pfister R897EBK Brushed Nickel Catalina Single Handle Shower Only Tri Logo
194 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
