Question about Panasonic PT-AE700U Multimedia Projector
Projector will not switch between eco and normal modes
Actually I am asking for help about Panasonic PT AE2000E projector that has locked up in one mode, dont know which one and light output remains the same when I switch between eco mode and normal mode. Any suggestions?
I.M
  • 1,512 Answers
Hi imustafa
Sounds like the lamp may be on its way out... at least is low on output.
Posted on May 05, 2008
  • Graeme Ross
    Graeme Ross May 05, 2008
    may be time for a new lamp to get the brightness back up on full mode.
    try here
    or here
    for replacements.
When I set my PT-D5500UL contrast mode to HIGH the picture have less light than when contrast mode set to NORMAL, is this okay or....because there should be more light when is set to HIGH?
I have a PT-D3500E and it does exactly the same as your projector. When setting contrast mode to high, the picture gets darker. I think this is o.k.
Oct 18, 2012 | Panasonic PT-D5500U Multimedia Projector
Panasonic projector PT-L78 - Cannot get ride of Lamp time error. To reset the timer
How long ago did you replace the lamp?
If the lamp has not actually been replaced and you are attempting to bypass this safety feature then I have bad news for you. Once the projector determines current flow through the lamp has exceeded the threshold amount, it will put the projector into the mode it is in now - Critical Lamp Replacement. You can set the projector bulb to low power output and see if that allows you to reset the bulb life timer but, again, if you have not actually replaced the bulb assembly, you are in danger of the bulb bursting under pressure. This can actually damage the projector.
You can find the manual for your projector at
ftp://ftp.panasonic.com/projector/ptl785u/pt-l785u_oi.pdf
Nov 01, 2017 | Panasonic PT-L785U Multimedia Projector
I have an panasonic pt-ae2000e projector, how do i get sound?
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Mar 21, 2011 | Panasonic PT-AE2000U Projector
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Hi!
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does...
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
May 10, 2010 | Panasonic PT-AE700E Projector Lamp
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Panasonic LCD Projector PT-L720V
Press 'menu' and 'enter' buttons at the same time.
Mar 18, 2008 | Panasonic Videoprojector PT-LM1E...
PT-LB20VU unit won't power on
check for the following:-.
1--the power cord may be disconnected.
2--main power switch is turned off.
3---no voltage(electricity)in wall outlet.
4-the lamp cover has not securely closed.
5--check for blown power fuse and change it with the same rate.
6--defective power supply unit.---.
Jan 21, 2008 | Panasonic PT-LB20NTU Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
