Question about Ridgid FactoryReconditioned 12 HP 5Gallon Mini Wheelbarrow Air Compress
I buy the oil- free twin stack air compressor 6 months ago at THE HOME DEPOT,and I used it just 2 time,and now when start it have noise(sound) but air blow weak Model is: 0F45175 HP1.8 P-SI 175 GAL 4.5
  • 9 Answers
SOURCE: Have rigid twin stack air compressor. Only keeps
possiably the " reed valves under the head are not closeing off all the way. These may be bent or somehow distorted their tension most of the time from exsesive heat. Good luck
Posted on May 19, 2009
  • 14 Answers
SOURCE: Dent in air compressor tank
was the tank creased? you can take it to a compressed gas refiller and ask them to pressure test the tank.
Posted on May 26, 2009
ollie reece
  • 1167 Answers
SOURCE: trying to fing out if compressor oil can be
yes buddy simple to do unscrew bolt on pump unit underneith or on front at bottom let it drain replace plug and fill till it is 1/2w way on sight glass or upto line on dipstick some on ebay
http://cgi.ebay.co.uk/Sealey-CPO1S-Compressor-Oil-1ltr_W0QQitemZ140344576982QQcmdZViewItemQQptZUK_Air_Tools_and_Compressors?hash=item20ad304bd6&_trksid=p3286.c0.m14
Posted on Sep 29, 2009
compman66
  • 169 Answers
SOURCE: the compressor fills up with air fine.AS i start
yes sounds like a defective pressure regulator, I would order a new one and replace it, pay attention to the flow direction when installing the new one, they have an arrow on them to indicate correct flow direction.
Posted on Nov 26, 2009
Bat1956
  • 585 Answers
SOURCE: Craftsman compressor is weak
You probably have a restriction in the regulator. You may be able to disassemble and clean it but you'll have to relieve the tank.
Posted on Dec 05, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I don't know how much oil to put in my air compressor
    This is a really hard question to answer - not in the owners manual or elsewhere on the Internet. I think I did find the answer for future reference for other people with the same question. The parts depot for this model of compressor list a 8oz bottle of oil so that should be the maximum amount of oil to put in. Also on the subject of oil please note that this compressor uses 5W50 synthetic oil. If you use regular oil your going to have all kinds of grief with it not starting easily and causing a lot of wear on start up.
    Dec 20, 2013 | Hitachi EC89 4 Gallon Twin Stack Air...
    Zero outlet pressure Porter Cable C2002 type 3
    The collar tends to break off of the plastic tip and falls inside the spring. I just repaired mine by epoxying the tip to a modified closet-maid wire shelf clip and stacking (3) #78 o-rings on the tip. The clip mod was a tap with a 1/4" chisel to remove the shelf hook, leaving just the "square" screw receiver. As it happened, the screw recess was the same size as the tip. Put a little epoxy into the screw recess, press the tip into it, clean any excess and let it set for an hour. Slip on the o-rings, align all the parts, thread the regulator cover back into place. O-rings are in the plumbing section at Home Depot, epoxy usually near the paints, clips near the wire shelving. Best wishes.
    May 19, 2012 | Porter Cable C2002 150 Psi 6 Gal...
    I have a 2 hp 4 gallon twin stack mint craft air compressor. I need the oil cap/ breather plug and also need to no how much and what kind if oil to put in the compressor
    30 weight Non Detergent Air Compressor Oil is what you should use, although any 30W Non-Detergent Oil would work. Quantity wouldn't be much since it's only 2 HP. As far as the breather plug/oil cap, you caould try FD & Sons Hardware @ 866-612-5454. They showed as being a Mincraft Distributor.
    Aug 18, 2010 | Garden
    Keeps blowing the breaker... only 6 months old
    This compressor is small however like other brands in this size range draw 13 - 15 amps. Thats quite a bit of power. The compressor has a thermal breaker that will begin to trip if compressor is hot. I am assuming that the breaker that is tripping is the one on the compessor. I have seen many hitachi breakers fail. Easy to replace with generic 20 amp, cost about $10. Before you replace anything, check amp draw with meter, if within specs try to determine what is causing heat.
    example:
    cycling too many times per hour (check manual for recommended)
    low power due to weak circuit or extension cord
    using generator for powering compressor (not recommended)
    using low quality oil (use synthetic if hot climate)
    air leaking from intank checkvalve back to pump
    If no reason to overheat then replace breaker on compressor to 20 amp but watch for overheating. Good luck
    Jul 09, 2010 | Hitachi EC89 4 Gallon Twin Stack Air...
    Power on are compressor, hear buzz, but pump did not start .
    if its just humming and not starting you may have a motor start capacitor on the motor thats bad and can't supply the starting voltage against the compressor
    May 09, 2010 | Campbell Hausfeld 28 - Gallon Air...
    I have a small Hitachi 2HP compressor,oil lube w/twin green tanks
    the air pressure switch is gone, get a professonal 2 fix it just incase anything should go wrong
    Nov 08, 2009 | Air Tools & Compressors
    Have rigid twin stack air compressor. Only keeps about 75 psi and keeps running. I do hear air from the exhaust port (seems normal). Haven't used it for a while. Any ideas? Thanks, in advance.
    May 18, 2009 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
    Ridgid air compressor OF45150A twin stack
    sounds to me like u do not have it on a big enough circuit, look on the name plate for FLA, this is the amps it pulls to start up, and size ur circuit for that amount.
    Dec 28, 2008 | Ridgid 17038 4.5 Gallon Oil Free Twinstack...
    Ridgid FactoryReconditioned  12 HP 5Gallon Mini Wheelbarrow Air Compress Logo
    Top Ridgid Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
