Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Ariens self propelled hit a rock will not start clanks and smokes Crankshaft does not seem to be bent. Somtimes kicks back when trying to start.
  • 755 Answers
If you have kick back or the mower backfires you probably have a partially sheared flywheel key.
The good news is they are cheap and designed to shear to protect the motor from damage.
You can take the recoil cover off the engine and then remove the nut that holds on the flywheel and gently pry off the flywheel.
You should see a mangled flywheel key that was under the nut holding the flywheel on. Take it to a mower parts store and match it up with a replacement. Put the new one back in and reinstall the flywheel.
That should do it! Good luck and be careful!
Posted on Aug 24, 2010
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a husqvarna self-propelled lawn mower/keystart with leaf bag. i hit a small tree root and now it wont start. the cord back fires a little when you pull it. will a bent blade stop it from cranking?
Hi hardister2...
Sounds like you sheared the key that holds the flywheel to the crankshaft, this is a common occurance when you hit something hard with the mower running.
You will have to remove the flywheel to replace the key.
No a bent blade will not stop the mower from running,but should always be replaced
It can cause problems later with the seal under the mower, it will start to leak oil.
Please take time to rate me
Jun 28, 2011 | Husqvarna Garden
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Aug 23, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Hit a rock -the mower makes a clanging sound -afraid to run it with that sound -what to do?
Don't run it at all! You probably sheared the flywheel key and/or bent the blade and it is hitting the lower deck housing. If you have hopes of it running again, it will require some work to get to the crankshaft to observe the condition of the keyway and key. The keys are made of soft metal and designed to break when the engine stops suddenly. Repairing one is a great learning experience (it keeps the engine in time)...but there is quite a bit of work involved but not too bad
Aug 09, 2010 | Poulan Pro 22" Self Propelled High Wheel...
My wife was mowing the lawn and she hit a rock. Since than the lawn mower does not start and when it tries to start a little smoke will come out of the carburator area. The mower is a Sears eager 1...
Unless the blade is belt-driven, like on riding mowers, then the blade is attached directly to the engine crankshaft. Hitting a rock with a mower like this is a very common problem. You probably have a bent crankshaft. In most cases this can be repaired, but may not be worth it, considering the age of the mower. But you should call a local small engine/mower repair shop to ask for an estimate. The repair is not something you would be able to do yourself.
Apr 30, 2010 | Craftsman Garden
Does the Toro self propelled have problems in rough areas . I have heard the crankshaft can be broken.
How do you define rough areas? If you are mowing a rocky area then, yes, there could be a problem. Otherwise, you should not have a problem, even if the mower is set too low to the ground for high grass or thick brush. The crankshaft does not break that easily, my friend; you would have to hit a big rock with the blade with enough force to break that crankshaft.
Feb 09, 2010 | Toro Lawn Mower With Toro Power Tools
Was mowing and hit a rock now the mower won't start, Blade is turning when I crank it but it doesn't even attempt to start
The flywheel key has sheared or partially sheared which throws off the spark timing. Removing the flywheel and replacing this key will put the timing back in place. If the crankshaft bent at all you will feel a new vibration when it starts. As long as it is not to severe and the blade is not hitting any metal it is ok to run.
Nov 30, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Flywheel?
THE BENT KEY CHANGES THE POSITION OF THE FLYWHEEL IN RELATION TO THE COIL SO THIS THROWS THE TIMING OFRF. BENT KEYS HAPPEN WHEN THE BLADE HITS SOMETHING HARD WHEN RUNNING LIKE A BIG ROCK OR A PIPE. HOPE THIS HELPS YOU
Sep 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I hit something with , when i start the lawnmovers it goes crazy
The vibration is caused by a bent blade and/or a bent crankshaft. The first thing to do is to replace the blade to see if the vibration goes away. If it does not then you have a bent crankshaft. The higher rpm's is not normal but is probably caused by a timing problem caused by a sheared or partially sheared flywheel key.
Sep 14, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
308 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
