Question about Datalogic QuickScan® QS6000 Plus (6660120010030201) Handheld Barcode Scanner
I have the PSC qs6000 plus scanner and need it to be reset to default where it can scan without a prefix in front. it reads code 39..
5 Suggested Answers
  • 244 Answers
SOURCE: Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Posted on Nov 05, 2007
  • 58 Answers
SOURCE: PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Posted on Jan 09, 2009
  • 192 Answers
SOURCE: ive got a second hand psc qs6000 plus barcode
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Posted on Aug 20, 2009
SOURCE: i scan barcode into notepad ....computer goes haywire
heare are the manual but i search a manual whear i can enable the code 93, has any a idea?http://www.barcodemuseum.com/Datalogic/Manuals/dlc6000_820000512.pdf
Posted on Jan 21, 2011
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
USB Interface
Keyboard Interface
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
Jan 27, 2009 | PSC QS6000 Plus Handheld
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
USB, SERIAL, PS2
Then...
First you do
then
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Psc qs6000 plus
If, during the programming session, you find that you are unsure of the scanner's settings or wish to reset the scanner's configuration, use the Return to Factory Settings label available in the Programming Overview section of the above programming guides. (Note: Use this label with caution, as it will disable ALL features that may have been programmed since the scanner's installation.)
Apr 08, 2008 | PSC QS6000
Psc quickscan 6000plus
That scanner has been constrained to accept a digit length of 12 or less .. probably IPC codes which are 12 digits in length.
Do you know the symbology of the barcode you are scanning? (i.e. UPC, EAN, I2of5, C3of9 etc).
Dec 27, 2007 | PSC QS6000 Plus Handheld
Obtain setup documentation
Here you go, hopefully this will work for you:
http://www.scanning.datalogic.com/html/manuals.htm
Specifically:
http://www.posguys.com/download/6000.pdf
If it does, please rate this as FixYa!
Thanks!
Dec 11, 2007 | PSC QS6000 Plus Handheld
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Aug 28, 2007 | PSC QS6000 Plus Handheld
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
Datalogic QuickScan® QS6000 Plus (6660120010030201) Handheld Barcode Scanner Logo
152 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
