Question about Nokia N900 Smartphone
My nokia900 show that I am connected to the internet but the green light that shows you are connetced keeps blinking in and out. why is this ?
  • Nokia Master
  • 4,737 Answers
There is nothing special about the green indicator. It simply means your phone is connected to the Internet and you are accessing. It'll keep blinking unless you are disconnected from the internet. Once you disconnect the net connection, you'll no longer see the indicator. As on other models like N70 or similar models, you'll see "G" or other similar indicators blinking while the phone is connected to the internet. So it's not a kind of defect or a faulty. It's normal and there's nothing wrong with it.
If you have further query, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 24, 2010
Have had the N600 WNDR3400v2 installed for over a month and all worked well until yesterday. I have an internet connection and the router info says all is good, i cannot get it to connect. I've tried...
The blue light indicates the wireless network is working, it is just that nothing is connecting through it.
The internet icon should be solid green or blinking green which shows it is connected to the Internet, if not connect your ISP.
Feb 06, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
How to confirm that the BSNL modem is having problem & cannot be used any more if INET light is continuously blinking?
There are several lights on your modem/router. Each one has a function and signals whether it is working correctly by the color it is displaying and a few other factors.
All of the lights on your modem/router should be green and solid - EXCEPT for 2 which are for your internet and wireless services. Blinking means activity. If you INET light is continuously blinking that means its healthy. Blinking means activity. The internet always has activity. The blinking does not signal your activity - it signals the traffic and connection on the internet. Your wireless connection also has a light which should show activity and availability. A blinking light on your wireless connection means that either someone is connected wireless and using the internet or that the connection is up and available for wireless access.
All of your lights should be green. If you see a red or yellow light - regardless of whether it is flashing or not - it means that there is trouble or problems that need to be corrected.
Each light is marked with its function. They should say things like "power", "link", Internet or INET, and "wireless". When you turn on the modem/router during your first set up, let it power up and finish its testing before connecting your pc and turning it on. The modem will test each light, make them all go from red/yellow to green - then make them all turn solid green (not in that exact order) and this is all normal. You will know when it is done when all lights are solid green and stop blinking and/or moving (except the INET & wireless lights which will be constantly blinking). When all lights other then those two are green and steady - then its time to connect the cable to your pc and power it up.
If you are having problems with your internet connection - you can rule out the cause being your modem/router by following the instructions above. When you rule out that the modem/router is not the cause, you can continue by checking your PC.
For a wired connection (wired meaning that you are connecting your computer to the internet by using a cord/cable) the first thing you want to do is make sure that the computer is automatically sensing the connection.
Your computer should automatically sense that there is a live internet connection when you connect the ethernet cord from the modem/router to the pc. When its working right, the computer will display a connection picture which is called an "icon" on the bottom right side of your screen near the clock area. Sometimes there is a downward arrow by the clock which needs to be clicked on to expland this area and show all icons for running programs. If you see a downward pointing arrow by your clock on the bottom right side of your screen, click on the arrow.
Test that it is sensing the internet connection by unplugging the ethernet cable from your pc and watch the bottom right side of the screen at the same time. Unplug it and repeat if necessary while watching the bottom corner to see a change which indicates it senses the connection. A normal internet connection icon looks like the picture of a computer monitor. Some glow green when they are active and the ethernet cable is connected. Some show a red "X" over the picture of the monitor on the bottom right side of your screen when the internet connection is down or not working. Some will say "cable disconnected" when you unplug the ethernet cord. Some show "Cable now connected" when you plug it back in. You should see something change and/or appear if your pc is picking up the internet connection correctly. When you have verified this as true - then you can continue on to the next step of troubleshooting the internet connection.
DSL service is an internet connection that is always on. Its considered a "live" connection. DSL connections usually do not require any set up (programming or changing settings). The only time that this is not the case is when someone tries to to set up a dial up connection like aol over the top of a dsl connection. You can check this by going to your control panel, click on internet options, and choose the "connection" tab at the top. In the connection area box there should be "nothing". The connection area box is for dial up connection settings. If a dial up service was set up in the pc it would show it here (you would see AOL dial up ect). If you see a dial up connection set up and you know that you have dsl, click on the remove box and delete it from this area.
You do not need to install anything from a disk to establish an internet connection if you have a dsl line. That means you dont need an "aol" disk or software to make the internet work.
to start the internet click on the blue "e" on your desktop which stands for internet explorer.
If you have any questions you can reply to my solution by going into the problem you posted on Fixya and click on the "reply" option.
Mar 03, 2011 | Samson Technology X6v ADSL ModemWireless...
Why do my Ethernet and Internet light keep blinking?
Some routers blink to show there is ACTIVITY on the ethernet and internet ports, For example you broadband modem is connected to a port on hte back of your router this has a light it would blink on some routers to show activity, and likewise with the ethernet side.
If you have internet access and have zero issues this is NORMAL.
thanks for your question please do rate your answer, Thanks
Aug 05, 2010 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Trouble setting up work laptop to use Internet thru home computer
Do you have any firewall installed on your computer?
If so, try disabling it. If it doesnt work, keep going.
does your modem have a green light on the "internet" or "activity" status? if not, you have a problem in your modem.
hope it helps.
Aug 07, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Modem keep rebooting.
It sounds like you have a bad modem. Have you tried to plug the device into a different power outlet? This will rule out that it's a possible power issue in the outlet.
If no change by trying a different outlet I would replace modem.
Hope this helps.
MO
Jul 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Modem keeps rebooting
This problem seems to be ISP based.. I'm having the same problems last 2 days with AT&T DSL
HP LaserJet 1300 is showing blinking of orange light instead of tonner is in
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
Apr 11, 2008 | HP LaserJet 1300 Printer
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Nokia N900  Smartphone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
