Question about Sony PlayStation Portable (PSP) Console
Ok so my little cousin let my psp fall and it charges but it just doesn't turn on
  • 4,102 Answers
Hi the good news is that it charges so the chances are the psp works but to me the problem sounds like the on off switch is damaged you will need to take this into a repair shop to have replaced as it requires special tools and skilled soldering doing, most phone shops offer psp repairs, not the big branded phone shops but the smaller phone shops and they will be your cheapest option for repair
let me know how you get on or if you need further assistance ok
Posted on Aug 24, 2010
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I hi have my psp and it dont want to charge i take the battery out and put it in my cousin's psp and it charges in his and when it's fully charges it works in mine..... so its not the battery, i...
You did a good job in isolating the problem. It does seem that your Power charger port is the culprit. I had the same problem with my unit. What I initially did was I applied slight pressure using my finger pushing the adapter plug in the direction of the start button. Apparently, there was a slight gap between connector inside the PSP charger port and the outside part of the adapter plug. Eventually, I added a small layer of solder to one side of the upper part of the charger plug ( near the top part which is colored yellow ). Dont put too much solder, doing so will cause the adapter plug to not fit inside the port. That fixed the problem for me. !!!As a reminder, please do this if you are experienced in using soldering tools !!!!
If your unit is still under warranty, I suggest you let the Sony Technicians fix it for you.
I hope everything works out. All the best to you.
Jul 20, 2011 | Sony PSP-3000 Black Console
I HAVE A PSP 1002 (ORIGINAL MODEL). the problem is that i tried charging the battery with the wrong charger (i had temporary lost the proper psp charger) this seemed to work for a little while until one...
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
My little cousin put me a lock code on my n97 and icant unlock it plzz help
1) ask them 2) if #1 doesn't work take something of your cousin's and hide it 3) if #2 doesn't work punch them 4) if all the above doesn't work repeat the process
May 02, 2011 | Nokia N97 Cell Phone
My original ac adapter for my psp burnt out I bought another adapter (universal) and after a couple minutes that one burnt too.Whats up?
its because your not suppose to use universal!!! my cousin has a universal and it takes for ever to Charge the charger was probably to weak for example the psp's charge is suppose to be 5 volts and the charger was probably 3 volts so the poor charger coulnt handle it and burned... try getting a new batterie. and a good charger
Apr 10, 2010 | Sony PSP (Piano Black)
PSP won't come on.
yes. the problem here is that adaptors dont convert voltage. so when you put the psp on charge in ireland it must have fried the circuits so that they wouldn't work. this means that the psp is ruined
sorry to be the one to tell you
Apr 21, 2009 | Sony PlayStation Portable (PSP) Console
Chargind psp
If it’s the 2000 series (PSP Slim), then yes. Connect your PSP system to an available USB port on your computer. Turn on your PSP, then under “Settings“, select “USB Connection”. Your PSP should connect to your computer and start charging. It may take awhile, but it will charge it all the way. Hold the display button (The button with the rectangular shape at the bottom of your PSP) until the screen goes black. This will speed up the charging process and is a good method of prolonging battery life when listening to music or other things.
If that doesn’t work, try looking for an adapter lying around your house that matches the volt numbers. The PSP takes 5V. Most portable CD players use 5V adapters and are usually the same size as needed for the PSP. I suggest using an adapter that matches the volt number and fits without trouble. If the orange light doesn’t come on or the PSP acts weird after charging, I’d stop using the adapter. Ask me any questions if you have any. ;)
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
Won't turn on
iv got the same problem also
i wz upgrading to 5.00 and it turned of,,, then it wont turn on,,it only shows green light
Jun 30, 2008 | Sony PlayStation Portable (PSP) Console
My psp is acting up
he messed up the whole screen its an internal problem your can try to call them to get it repaired or buy a new one
Jan 17, 2008 | Sony PlayStation Portable (PSP) Console
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
