Question about Classic Accessories Arrow Backpacker Pontoon Boat
The first time I used the boat. I got about 100 yards down the river and the frame broke? I need to contact a place I can return and get a new one? Feel free to give me a call @ 303-674-1105 Thanks Mike
7000 double horse ep racing boat broke.
it is the force you aply to some thing and all that
Mar 03, 2014 | RC Gigantic Cyphelurus EP Racing Boat
Have a Yamaha GP1200R. Been running fine until yesterday. Took it to river and got about a mile down stream and it shut down. I let it cool down, it fired up and went about 100 yards and shut down again....
It sounds like it might have a bad coil. I have had coils do this on me in the past on a few motors. See if you can find another coil just to try it and it this is the problem then just buy a new coil and replace it.
Mar 14, 2011 | Yamaha Boating
Need a motor boat in the game
you have many motor botes in GTA 3 and GTA Vice City as well,
you can get them when you go to sea or river like area.
to go there, you can get any car and drive it on water using the cheat "saways" .. with this, you can drive any vehicle (Except Bikes) on water. Go to the boats, find some step/place to change from the car to boat..
once you see it, you will find the way,,
Apr 14, 2010 | Rockstar Games Grand Theft Auto III & Vice...
I need to manufacture a boat trailer for a
I have some tips I learned from finding a trailer for my 27 foot cruiser. Really, you can find deals in this economy that make rigging a trailer from scratch too much work.
You need to find the loaded weight of your boat and where the hull needs support from Carver. Your trailer needs to hit the "Chines" correctly, meaning the bunks have to be adjustable to the contours of the hull.
The bunk supports can fit outside, inside, or on top the frame rails Mine started on top of the rails and were converted to the torsion axles, requiring new supports.
The axles need to support enough weight and State laws will say how many axles need brakes. Your choice of electric or hydraulic. The bunks should be made of Cypress, but synthetic decking could be cheaper. Your tires should Load rated D or better and 15 to 16 inch wheels, not 14 inch because of the weight.
There are numerous Boat Salvage yards listed online.
There seems to be a "thing" about the region the boats are used. Some places have orphaned trailers everywhere and others are always married to a trailer.
I have seen Boatyard liquidations with ridiculously cheap trailer prices. Use the internet and look.
Feb 06, 2010 | ShipShape Pontoon Boat Trailer Guide-on...
Rear suspension rusted out and dropped body down on wheels i believe that the upper suspension bracketry has pulled away , the air sup. will raise it up agin but that is not safe. please help
your problem can be simple or it can be terminal u have to jack up vehicle and see exactly what went-- if spring and shock tab bracket broke off if upper frame broke/rotted ---most everything on frame can be replaced bolted/welded back on can get parts from salvage yards ,online and or dealer even frame can be channeled welded but it will be labor intensive if u weld or know a welder the parts are simple enough its the frame sectioning that will be ur costly problem if needs replacement good luck
Oct 27, 2009 | 1990 Chrysler New Yorker
If a boat will hold 150lbs and the mother weights 150lbs
The two daughters cross first, one returns. Mother crosses, alone. The first daughter returns, both daughters cross.
W/D
Sep 15, 2009 | Arrow Boating
Sevylor river xk2 does not track well on still water
This inflatable kayak is meant to turn to facilitate maneuverability in whitewater; it needs to turn.
Try attaching piece of plastic as a skeg, perhaps the skeg from the Sevylor Tahiti will suffice (or a piece of lucite or a plastic cutting board). A skeg makes a boat track straight.
My Sevylor Colorado came with an optional skeg which I only attach on flatwater (never whitewater).
Aug 14, 2009 | Sevylor Inflatable River Xk2 Kayak
On the GPS Garmin the radar screen shows our boat turned the wrong way. How do you turn the boat around on screen?
My husband moved the boat slightly and it seemed to correct the radar screen somewhat. He is working on the whole boat at present so didn't want to take it completely for a drive down the river. If we have further problems we may call in or use the web site.
Thanks,
Farrar
Jun 23, 2009 | Garmin Gpsmap 4208 Network Bundle
Classic Accessories Arrow Backpacker Pontoon Boat Logo
Top Classic Accessories Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Classic Accessories Boating Expert? Answer questions, earn points and help others
