Question about Hifonics BX1500D Car Audio Amplifier
I have a Hifonics Brutus BX 1500 D-Class Mono amp. All of my lights turn on and it doesnt go into protect mode, but it doesnt push any power to the subs and if i leave it on to long it blows a fuse. I also notice it heats up alot right by the fuses. Could anyone shed some light on this for me? thanks
5 Suggested Answers
  • 1596 Answers
SOURCE: 2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Posted on Jan 29, 2009
  • 631 Answers
SOURCE: problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Posted on Dec 27, 2007
bigTROY502
  • 129 Answers
SOURCE: I got a hifonics brutus 2000w class d amp, it went
Either bad RCA's, Bad RCA ground from the radio, or blown suibs.
Posted on Aug 14, 2009
  • 16 Answers
SOURCE: how to bridge a amp brutus hifonics 1200 watt
use the first - and the last + should run at 2 ohm then
Posted on Mar 10, 2010
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
Amp not working
sounds like the amp is going into protection mode. maybe a sub is shorted (blown). Or, the only other possibility is the mosfet transistors on the inside of the amp are blown.
Feb 01, 2010 | Hifonics Brutus BX 1205D Car Audio...
!!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
Cant get protect mode off on amp
you burned up a couple of dioeds if if wnt go back to a regular mode
Apr 01, 2009 | Hifonics Brutus BX 1605D Car Audio...
No output
Maybe you should check your remote wire!
Apr 16, 2008 | Hifonics Brutus BX 1605D Car Audio...
Problem with hifonics 1505 class d mono
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Problem!
you have a foulty amp i wtake it bk and change it
Okay i have a problem hifonics brutus 1500 mono d class amp
well your amplifier is obviously going into protect mode,(i used to have this amp and it is awesome) anyway i would go through just to be sure and check all the power connections with a test light, remote wire, positive, and ground. and check the fuse to see if it is still good. you can buy a test light at wal-mart and any automotive store. if you stil have a problem then i would check to see if your running below 1 ohm on this amp. that would cause it to go into protect mode. if all this fails i would just go buy a new one.
Oct 07, 2007 | Hifonics Brutus BX 1505D Car Audio...
Hifonics BX1500D Car Audio Amplifier Logo
334 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Shehu Pro
Shehu Pro
hoyzee1
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
