Question about Refrigerators
Fridge stopped cooling! Any ideas - Refrigerators
  • 6,784 Answers
If you are not hearing the compressor cycle on and off in intervals and there is no air flow present inside the unit, this will confirm that there has been a severe malfunction within the units assembly. You will need to check the following areas for faults:
1. Compressor- Make sure this unit is functioning. if it is not cycling as designed, this will be the culprit. If it is cycling but very hot to the touch when operating, check the condenser coils for debris and clean them if necessary.
2. Compressor start relay - This is the main on/off switch that is attached to the side of the compressor. This relay, when energized by the main control board, starts the compressor. if the relay has failed, it will not start the compressor, thus, rendering the unit inoperable. Pull the relay off and shack it. If it rattles, replace it.
3. Evaporator fan - This is a very important part of the evaporator core. This is the principal air mover of the unit. If this fan fails, the inside freezer and refrigerator will not cool, at all. You will need to remove all the freezer shelves and content to access this unit. It is concealed behind a panel inside the back section of the freezer compartment. Once the concealment panel is removed, you will expose the core and fan. the fan can be tested with a multimeter for proper continuity. You can also jump the terminals with a jumper wire to see if it is still in working order. An external power source will be needed for this test. if the fan fails the test, replace the fan motor.
4. Condenser fan - This is also a very important fan. This fan is mounted near the condenser coils and can fail. You can test it in the same manner as the evaporator fan. replace the condenser fan if it proves to be damaged.
5. Main PCB(Printed Circuit Board)- This is basically your main power controller. This board routes power to all the fans and compressor unit located in the assembly. it also routes power to the lights and ice maker/dispenser, as well. This will be the most expensive repair, in this case. If all the above areas prove to be functional, the main PCB will be the culprit. You can easily locate this board. It is usually mounted on a bracket, near the compressor platform, or behind a concealment panel on the rear of the unit. Once you have gained access, visibly, inspect the board for burn markings at the relay mounts and jumpers. check the entire circuit board for discolorations like brown marks or black burn marks at the plug-in connectors. If this refrigerator is totally dead, this will be the cause.
6. Monitoring thermostats - These are located in each compartment. Replace each thermostat if all the other checkpoints prove to be ok and in good condition
7. Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
You will find the culprit in one or all of the areas stated above.
Posted on Aug 24, 2010
  • Michael Masters
    Michael Masters Aug 24, 2010
    • Additionally; Be sure to check the door gasket(s) and the door switches, as well. You can press the door switches in to test. If the lights don't shutdown when the door pressure switches are pressed in, this will confirm that those switches are damaged.
No cooling on a Mini Fridge
Does the compressor start up? It has a thermal cut off and a current stareter relay that tend to go out causing the compressor to do nothing without power in it.
May 15, 2018 | Refrigerators
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
Refridgerator stops cooling
Check the compressor relay near the compressor on the back bottom of the fridge. Check voltage it should read about 115, up above that there is a computer sensor, check that also has a fuse on it. One of the two is bad, they are cheap part and you can find them on LG.com
Feb 09, 2009 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
Fridge not cooling
You most likely have a thermistor that needs replacing. Can you tell me the the temp. in the fridge? Most LG fridges have a 1 year warranty with extended warranty on some parts. If you could provide the model #, I can look into it further for you.
Feb 03, 2009 | Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
