Question about Bosch Water Heaters
Bosch Hot Water on Demand Tank W325-2 KV1 P31 Model..Ignition Problem Having trouble igniting the pilot light via holding in the button and clicking the igniter. And if I ever do get it lit, the gas goes out when I depress the button that lets the gas through. I have plenty of gas in the tank. Just can't get it to ignite and/or stay lit. If I do ever get it to stay lit, the pilot will go out after 2 showers. Could it be my Thermocouple? If not what? Thanks
  • 2692 Answers
SOURCE: Gas tankless water heater turns off during shower
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Posted on Feb 23, 2009
kevin000
  • 1847 Answers
SOURCE: Bosch tankless GWH 1600 H NG won't always ignite
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Posted on Mar 29, 2009
co7196
  • 3433 Answers
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Posted on May 06, 2009
  • 6 Answers
SOURCE: Bosch Water Wizard 600 pilot light keeps going out
You need a new thermocouple. Its the little stick like thing that the flame heats up to tell gas valve to open.
Posted on Jun 15, 2009
  • 6 Answers
SOURCE: water heater pilot light won't stay lit
Only thing left to change is the gas valve assembly.
Pilot not light
Sounds like you have a hydro-generator on this unit. Check the output on the hydro-generator it should be about 1.5V DC. If not clean the inlet screen and check your water pressure. Water pressure less than 30 PSI will cause issues. If you have 1.2V-1.5V DC make sure the power switch is on. If the power switch is on replace the control unit. I sell parts for Bosch units only!
Apr 02, 2014 | Bosch & Tankless LP Hot Water Heater
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Cannot find pilot light on my bosch GWH635ESL, help!
Call Bosch
Gas Products Technical Support: 800-642-3111
That model number is only shown at one website, and that model number is not shown at Bosch.
Open following link for Bosch:
http://www.boschwaterheater.com/BoschHotWatercomHome/GasProducts/tabid/331/Default.aspx
Search of Bosch for that model number shows no result.
Some water heaters do not have a pilot light. Instead they use hot surface igniter rod that glows red hot
The igniter rod ignites the gas after solenoid valve opens and gas flows to combustion chamber.
The igniter rod and heat sensor have to be operational, and have to be positioned correctly for ignition to take place.
If igniter rod is not working, or if heat sensor does not detect flame, then gas solenoid valve shuts down and water heater does not heat water.
Sep 03, 2011 | Bosch Water Heaters AquaStar - Tankless...
I have a Bosch Tankless Water Heater Model WR 400-1 KV1 P32 S3100. The water valve has cracked and I need to know where to get a replacement. Thanks
Before calling service technician, open following link for Bosch troubleshooting resources including parts, contact, possible manual, possible service bulletin covering replacement:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Bosch Water Heaters
5yr. old aquastar 125x lp wont stay lit after about 5min. use. just started happening out of the blue... a clicking noise preceeds the flame shutting off. any ideas?
The gas valve makes a single click sound when the pilostat shuts off. That is a safety holding coil for units with standing pilot lights and closes if it thinks the pilot went out. In electronic ignition, the same holds true except the sensor is electronic.
Mar 31, 2011 | Bosch & Tankless LP Hot Water Heater
No hot water coming out. ignition comes on ,but no lighting of gas. There is gas in bottle and it's on as normal.Works one day , doesn't the next.I cannot remember if there was a pilot light before!
check for pilot but im sure that the pilot is on demand thats what makes these things so cool and inexpensive to operate. try having someone turn on the hot water while looking for ignition. if there is nothing it may be a relay. im not sure but if you open it up check for a 3 amp fuse its green. all the new furnaces with mother boards have a fuse. I am not really a heating guy but i have been looking into on demand systems and sat in a training session at the plumbing supply. never hurts to try and help.
if its not a fuse or the ingniter isnt functioning you may need to call a heating person who knows on demand or check Bosch on line maybe they have the trouble shooting guide if you dont.
sorry that all i can suggest hope it helps
Dec 04, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
No hot water, pilot light lights but no burner ignition
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
