Can not set up philips 42pf5521d/10 press ok but no responding
Did you get the tv sorted as ive the same fault any help would be great
Posted on Dec 13, 2010
Philips 42PF5521D will not switch on
The main digital board should be suspected. Check this for more details. There are so many reasons for this fault. The flashing of LED at its front panel denotes this. Count the number of flashes. You can get more details form the site linked above.
Dec 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Mune shows up suddenly at anytime, side menu button doesn't respond
had the same problem, did a software update and it fine now.
you can update at site for your tv.
Nov 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
MY PHILIPS WIDESCREEN KEEPS TURNING ITS SELF OFF
CHEEK UR POWER SETTING AND SLEEP TIMER YOU WILL FIND THE SETTINGS IN UR MANUEL......MAKE SURE SLEEP TIMER IS SET TO OFF
Nov 19, 2009 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My philips got green light on no pic.
Press and hold the menu button on the side and hold for five seconds, that will reset the tv ------------- do this after you have checked your manual for other troubleshooters, you know, the obvious 'correct channel i.e EXT1, EXT2, TV'
Nov 06, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
