Question about Hayward 1.5 Hp Northstar High Performance Pump
I have Hayward EC-45 filter leaking DE into pool via return line every start up. Checked all troubleshooting causes (tube tears, bad gasket, cracked tube sheets, loose bolts, o-rings, etc. All looks OK to 3 pool specialists. I'm out of ideas...can you help?
  • 366 Answers
If D.E. is returning to the pool, it's usually because you have a tear in the grids or the backwash valve is not working properly and returning D.E. back to the pool.
Posted on Aug 25, 2010
  • 1 more comment
  • mr_blobster Aug 26, 2010
    I don't have backwash or a backwash valve,
  • Dale Cobb Aug 26, 2010
    I apologize, I need the read the model number more carefully. I'm no expert on this particular filter, my expertise is with -ground gunite pools. However, if the D.E. is returning, there has to be something out of place or damaged to let it through to the return lines.
    I am surprised that three different pool techs could not diagnose and repair it for you. I wish I could see it in person, these type of things intrigue me.
    Hopefully you get it taken care of soon, I'm sorry I could not be of more help.
  • mr_blobster Aug 31, 2010
    THANK YOU FOR YOUR TIME
After start up the de keeps coming back into the pool? Help?
If you have DE leaking in through the return lines, there are a couple of things that you should check. You probably having an opening or tear in one or more of your flex tubes. If that is the case, you will need to replace the damage tubes and the problem should be corrected. There could also be a rip or tear in the pool filters diaphragm gasket or it could be worn or loose. If you notice a problem with the diaphragm gasket, replace it. You could also have loose bolts on the tube nest plate. Try tightening these bolts.
Jun 25, 2011 | Hayward EC-40 DE Pool Filter with pump
I installed a complete hayward filter with a new multiport valve. i can see DE in my pool. what would cause this? Thanks for your help.
If these Hayward pool filters are leaking DE back into the pool, there are a couple things that you will want to check. Check for loose bolts on tube nest plates and tighten them if necessary. Make sure that you don't have a worn or loose fitting diaphragm gasket and that there are no rips and holes in it. Replace the gasket if any of these is the problem. Check for openings or tears in one or more Flex-
Tubes and replace them if necessary.
Dec 19, 2010 | Pentair Clean & Clear Filter and Dynamo...
I replaced the diaphragm gasket and when I bump the filter some DE still shoots out into the pool. all the tube sheet hex screws are all tight. Paul
There are several things to check when correcting DE leaks in these pool filters. If you have already replaced the diaphragm gasket and tightened the screws, check for an opening or tear in one or more Flex-Tubes. Replace them one or all as necessary. Make sure that you have the proper amount of DE and that you don't have holes in your grids.
Oct 03, 2010 | Hayward EC-40 DE Pool Filter with pump
I bought a used Hayward Perflex Extended Cycle DE Filter Model#EC45 I have to keep backwashing it, it flows heavily back in the return but it only flows good for a little while. What do I need to do? It...
Here is a link to the hayward manual. Be sure to follow the pre-coating insturctions carefully.
Use only the swimming pool grades of
diatomite, such as:
CELATOM . . . . . . . . . . . Eagle-Picher Industries, Inc.
AQUA-CEL . . . . . . . . . . Johns-Manville Products Corporation
DICALITE 4200 . . . . . . . Grefco, Inc.
WITCO . . . . . . . . . . . . . Witco Corporation
The EC-50 filter uses a 5 lb. (2.3 kgs.) charge of diatomite (D.E.)
Here is a link to the hayward manual for a EC-50 I think its almost the same as the EC-45
http://www.haywardnet.com/products/manuals/pdfs/manual10.pdf
Jul 01, 2010 | Hayward EC-40 DE Pool Filter with pump
I have the Hayward EC-40 Filter, my problem is the DE is getting into the pool. What would cause this?
Broken/torn grid, o-ring bad in the housing by the grid assembly or grids not in manifold properly. Backwash, open the filter, remove and inspect the grids (the plastic bases too).
Jun 05, 2010 | Hayward EC-40 DE Pool Filter with pump
I'm getting DE back in my pool from the 4820 filter
One of two things can cause this. Either the spider gasket is bad or there is a rip or tear in one or more of the filter grids.
P.S.
(the spider gasket is inside the valve you turn to backwash filter)
Mar 25, 2010 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
Hayward pump wont prime. air bubbles coming back into pol with water and de
You have a leak, if DE is getting back in pool your filter is either dirty and needs to be taken apart and throughly cleaned, or you have a ripe in one of the DE cells. The pump not priming is a leak somewhere before where water enters pump. Could be a bad o-ring in a valve. Hard to tell what is is without troubleshooting, piece by piece. I would start with cleaning Filter first.
Jun 17, 2009 | Hayward EC-40 DE Pool Filter with pump
We have an an Infinity DE filter. It's blowing DE back into the pool. We've replaced the filters.
Most likely the "fingers" inside the filter housing are worn out and causing the DE to blow out the return line to the pool.
Jun 12, 2009 | Hayward EC-40 DE Pool Filter with pump
Hayward 1.5 Hp Northstar High Performance Pump Logo
458 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
