Question about Maytag Refrigerators
Maytag MF D2561 HEB- bottom freezer refigerator- the inside water dispenser isn't working, though filter is new. I believe the solenoid may be shot. Can this repair be done by a do-it-yourself person?
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: frig not cooling
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Aug 01, 2008
t0pc4t
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
  • 531 Answers
SOURCE: water dispenser stopped working
check water valve or water line is kink
Posted on Apr 06, 2009
woodchuck789
  • 4066 Answers
SOURCE: water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Posted on Oct 05, 2009
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Freezer & Refrig does not get cold
without a model number to check out what else might be in that area of the door i'd say a piece of tubing from the water source is leaking, or you are getting ice melt from inside somehow making it out through that panel now. i believe the water for the door comes in through the bottom of the freezer door and works its way up to the dispenser area, the solenoid for the water inlet is behind the fridge near the bottom (you'll see the water tubing).
more likely somethings just not fitted or aligned properly and waters making it out someplace it shouldn't.
best of luck to ya
May 27, 2010 | Frigidaire FRS26H7CS Side by Side...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
HOW DO I CHANGE THE WATER FILTER - I BELIEVE THAT THE ICE MAKER IS NOT WORKING BECAUSE OF THIS
The icemaker is probably NOT run through the water filter. Typically the filter is only for the water through the door. Either the water solenoid valve that supplies water to the icemaker is bad or the icemaker is bad.
Mar 03, 2010 | Maytag MFD2561HE Bottom Freezer French...
Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
Nov 11, 2009 | Maytag Freezers
Maytag Ice20 not dispensing water
Hi!!! make sure that your water reservoir is not frozen located inside the frig section on the way back. If not the you have a bad water valve located in the back of the frig on the bottom..Good luck..
Dec 31, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
53 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
