Question about Kyocera Mita Kyocera-Mita SCANNER RACK Copier
Document feeder doesn't work. I'm looking for this part (possible part # SRDF-1)
  • 61 Answers
How do you clean rollers on manual feeder
To clean the rollers or separator pad
1. Remove all originals from the document feeder tray.
2. Lift the automatic document feeder cover (1).
This provides easy access to the rollers (2) and separator pad (3), as shown below.
1 Automatic document feeder cover
2 Rollers
3 Separator pad
3. Lightly dampen a clean lint-free cloth with distilled water, then squeeze any excess
liquid from the cloth.
4. Use the damp cloth to wipe any residue off the rollers or separator pad.
NOTE: If the residue does not come off using distilled water, try using
isopropyl (rubbing) alcohol.
5. Close the cover of the automatic document feeder.8_29_2012_4_02_48_pm.jpg
Aug 29, 2012 | Dell 1135n AllInOne Laser Printer
Tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 | Xerox C2424 Copier
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Document Feeder jams
I got adventurous and removed the screws holding the document feeder. I then used a can of air and blew into the gears and then reassembled the feeder. It works perfectly.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Feeder and glass product offset copies
check if the mirors are fixed and if not, bring them to the initial position! it's possible you should make an immage adjustement because teh scanner moved from the innitial position!
Nov 03, 2008 | Ricoh Aficio 2015 Copier
Check Document
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Aug 28, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Document feeder does not work
cleaned some sensors under the feeder, if possible, clean it with blower to solve the problem.
Aug 04, 2008 | Canon NP 6050 Copier
Printing line on each copy
Most likely there is something on the seal glass, Open the feeder and look at the small strip of glass, see if it is dirty.
the other possibility is that there is a streaking problem in the drum cartridge or in the fuser in that area.
Start with the glass, then look at the drum, You will most likely find the problem on one of those 2 areas.
I really suspect a small spot on the glass where the paper passes over when making the copy through the feeder
Feb 12, 2008 | Office Equipment & Supplies
61 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
