Question about Dewalt DC500 Canister Wet/Dry Vacuum
How do you dismantle dewalt dc500. Ive removed the screws but cannot separate black plate from yellow housing
  • Dewalt Master
  • 1,896 Answers
Posted on Dec 02, 2015
2 Suggested Answers
  • 67 Answers
SOURCE: My Dewalt dc500 only works on AC power (plugged in
Check battery contactor on the vacuum and on the battery. It is a common problem on this vacuum. Check for bent pins and corrosion.
Posted on Sep 16, 2010
Why dewalt dc500 vaccum only works for a few seconds
It sounds like the batteries are at the end of their lifespan.
Jun 14, 2014 | Dewalt DC500 Canister Wet/Dry Vacuum
My DC500 works fine running on battery power, but the motor hesitates for a moment or two when the unit is switched on with ac power. After this it works fine. What might be wrong?
may be the carbon brushes are short or motor connectors have become bad connection by moisture and dirt by use temporay a wrong filter sometimes its a very light and simple motor johnson motor with hammer brushes
DeWALT DC500 Type 1 Vacuum Parts
Mar 13, 2011 | Dewalt Vacuums
My Dewalt dc500 only works on AC power (plugged in to wall socket). When you put in the battery it doesn't work. Can anyone help?
Jul 13, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Dewalt dc500 won't **** in water
there is a float ball or reed that closes off the exhaust port inside the canister, to prevent water from filling too high when used as awet vac. If lodged or trapped it will prevent suction or discharge in wet and dry modes. look at the housing that the filter attaches to and you will see it. if it doesnt rattle when you shake the unit up and down, it is stuck; otherwise, you must not be spinning the fan blades.
Jun 23, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
DeWalt DC500 wet/dry vacuum
I had the same problem and traced it down to the on/off switch. I sprayed some electical contact cleaner down inside the switch and now it works normal. Hope this helps.
Oct 23, 2008 | Dewalt DC500 Canister Wet/Dry Vacuum
DeWalt DC500 Shop vac
the problem on your vacuum is the dc - dc converter.u cna replace them but to follow the same connection.
Oct 02, 2007 | Dewalt DC500 Canister Wet/Dry Vacuum
Dewalt DC500 Canister Wet/Dry Vacuum Logo
375 people viewed this question
Top Dewalt Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pcm2048
Are you a Dewalt Vacuum Expert? Answer questions, earn points and help others
