Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
I connect the power source then i connect it to my computer and it don't turn on at all...no light. Whats wrong
    Problem Solver:
  • 5 Answers
Needs to be recognized to turn the drive on via usb. if desktop, try a port on the back of the computer. Else go into control panel/system/hardware and delete and "unknown device" then right click on the computer in that applet and select scan for changes.see if it picks it up. also try cycling power to the drive while it is connected ( reverse order - connect then power)
Posted on Aug 24, 2010
Lg screen cant display. turned off after about 30 mins
Sounds like its not receiving a Signal, I would try changing your source (VIDEO) cable and trouble shoot the source itself, whats pushing the LG? If its a cable box I would unplug it for about a minute and plug it back in. Test your connection on a dvd or computer to see if it will get an image from another source if it does then the problem lies with your cable company and the box need to be fixed or replaced.... LGs are durable TVS Its very rare that I have to actually go on site to fix one its normally done over the phone because the problem is usally the source not the TV>
Dec 27, 2013 | Televison & Video
It dose not starts I don,t know whats wrong
When Jigsaws do not start, you have to check the power to them is good. Try checking the power socket by plugging a light into it instead of the jigsaw.
Sep 13, 2013 | Saws
I have an old hp v75 desktop that the monitor won't turn on all the lights are working, fan running, nothing wrong with the power supply, but when I press the power button it turns on, but the monitor...
First remove the vga cable from the desktop and see the monitor shows no conection if showing there is no problem with ur monitor if not change the monitor if showing conect the cable back to ur desk to vga port then check the ram remove the ram clean the surface with clean cloth then rub the print using an eraser then insert the ram and switch on if still no display change the ram if still not working remove the processor heat sink na clean th surface of the processor and the heat sink apply a thin layer of heatsink solvent or thermal paste fix the heat sink then restart the computer
Jun 29, 2012 | Computers & Internet
Everytime i turn the car off it resets the headunit whats wrong with it
is the yellow wire connected to a constant power source? the yellow wire needs to be connected to a source that still has voltage when the key is off, as it controls the memory of the radio.
Feb 28, 2011 | Car Audio & Video
Computers has power but will not turn on monitor,fans on blue light on, yellow light constant. cd slide opens and closes normal.
First the obvious, monitor is on? Cables are connected securely to back of monitor and PC? Power cable/power adapter are all connected and plugged in? If a power adapter is used, it will feel warm.
I am assuming it was working on some point and then stopped.
If you are getting power to monitor and it's power light is on, then I'd suggest a problem with the video output on PC
If you are not getting power to monitor or it's light is not on, the problem is with the monitor.It may have gone out on you. Try attaching to another computer.
Oct 05, 2009 | E-Machines T6528 PC Desktop
When i turn my computer on the big button which is usually green doesnt work. there is a smaller light which is also usually green just below the big one which starts green as i turn it on and then it goes...
Make sure your cables are all firmly connected. Also check the power strip or surge protector. If all is connected well and the pc will still not turn on it looks like the problem is the power supply unit, which can be replaced for around $20. I hope this works :).
Aug 16, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
My 18inch Dell monitor does not turn on.
first --
is it plugged in to the power source and the pc properly?
also-
check to make sure the power button on the monitor is on.
if these are not the problems --
could be a driver problem
what operating system are you running?
Dec 25, 2008 | Smart Modular SV3170A
Whats wrong with my lanzar amp
check ur ground wire , it might not be good ground, secondly check ur fuses..
Dec 25, 2006 | Lanzar HTG264 Car Audio Amplifier
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
37 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
