Question about Invacare HTR5500 Tilt & Recline Wheelchair
The invacare tilt wheel chair will not stay in the upright position . It gradually lays back
  • 68 Answers
The release cable for the back is preventing the cylinder from locking. Adjust the cable just like you would adjust a bicycle hand brake. Adjust the cable so there is a quarter inch of play in the release lever. Look along the cable for a adjustment section.
Posted on Apr 30, 2011
Have a Invacare Pronto m51 Sure step. Trying to change batteries and the seat seems to be stuck
Turn chair on its side. get spray pb blaster on it. set chair upright and wiggle seat back and forth to loosen. It takes work but after it is apart use grease on mating parts so they do not stick together anymore.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aug 01, 2016 | Invacare Health & Beauty
My son has a invacare chair should go 6 mph but has slowed to a snails crawl. How Can I speed it back up?
The chair may be in what they call SLOW MODE or the batteries are weak. If you have powered seating on the chair the seat has sensors that make the chair drive slow or not drive at all when the seat is tilted or reclined or raised. A sensor can go bad or get out of position. The joystick could have different programming for different drive modes. Try changing drive modes.
Jun 11, 2014 | Invacare Supply Group Pronto M61 Standard...
How would tilting the chair cause it to stop operating?
Look for safety features when chair tilted, damaged safety inclination limit
May 28, 2014 | Invacare Nutron R51
How do you correct or replace the Apex 2000 Storz exam chair that will not hold in position when tilted back?
This should be visually diagnosed to get an accurate identification of the issue. That said, I would look to the tilt motor having broken teeth on the sprocket or a broken drive gear. Also the drive chain may be loose enough to allow it to slip on the sprocket. In most cases, the issue is with the tilt motor mechanism. Removing it will determine if an adjustment is all that you need or if it needs replacement.
May 12, 2014 | storz SMR Apex 2000 Exam Chair
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
I can't remove the seat from an Invacare Pronto M91 VA chair with elevating seat.
single post, lift handle to rotate then pull up very hard!!! four poster lock is between knees release tilt back and remove
Oct 28, 2012 | Health & Beauty
How to move dead electric wheel chair
There are two levers, one for each motor, you have two. Depending on model either right under your knees (M51) usually, or under the rear, near the back casters. Typically black rubber on a metal rod. Move both in opposite directions, either both out, both in, or some types, both up, or both down. Sometimes they need wiggling, turn the chair OFF then try moving it in each position, (both in or both out). Google the manufacturer, your case invacare, they have detailed instructions there.
Jul 08, 2012 | Invacare Pronto M51 Power Wheelchair
Invacare power chair model #1089384; is stuck in the reclining position and won't come back up
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Jan 18, 2011 | Invacare Health & Beauty
Can you bypass the tilt recline mercury switch on pronto m 91
The mercury switch for the TRSS (tilt recline single switch) is a mercury switch with a molex connector on the end. The switch opens and closes depending on the angle of the chair with mercury or a ball closing the contact.
Yes, you can bypass this switch, I do it all the time when it fails. Follow the wire from the black torpedo shaped switch. Unplug the switch at the white molex plug eliminating it from the circuit. Inspect where it was plugged into and observe the female contacts in the molex connector. Take a paper clip and bend it to shape inserting it in the two female contacts, shorting across them. This, in effect, acts like a closed switch. Tape up this connection with tape to hold the paper clip in the connector. Use the same tape to secure the connection to the chair.
When you replace the mercury switch the new ones that are available are the new ball switch type. The mercury has been removed due to environmental concerns. The angle of this switch when installed should provide drive lock out at the factory specification of 20 degrees tilt. Mark the position of the old switch and wiring before removal. It is usually easier to get to this switch by removing the chair seat pan first. Adjust the angle of the new switch (about $70) on installation. You may have to cycle the tilt up and down several times to accomplish this, testing for drive lockout at 20 degrees.
You can safely drive the chair until a new part is obtained but remember you are defeating the safety feature of the drive lock out in tilt by bypassing the switch. When you are tilted back too far you can tip over so exercise caution when going up ramps and inclines. Hope this helps.
Nov 28, 2010 | Invacare Supply Group Invacare Pronto M91...
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
Invacare HTR5500 Tilt & Recline Wheelchair Logo
203 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
