Question about Sony KP-51HW40 51" Rear Projection Television
Hello I've 2 problems 1: I see green curved line running from side to side, and the last line at the bottom of the screen is curve the opposite way then all the others green lines, the green lines stay there even when switching input/source 2: I see what seems to be like a tear(scratch), on what is behind the protective sheet of plastic. The tear isn't on the surface plastic it's under it. 60pounds dog might have jump on it trying to catch the cat on top thanx in advance
  • potoum13 Aug 24, 2010
    thanx it answer my question of fixing it myself.
    any idea on how much it would cost(range price), polarisation readjusted and the 'layer' for entire screen?
    I want to know if it's time to invest in a new tv
    thank you very much Mr Azraelsrl you answer everything
  • Sony Master
  • 11,800 Answers
1 - the green light is the return beam from the green CRT - it should have been blocked; this happens when, because of old age, the polarisations of the tubes go off; the aged components must be replaced and the polarisations readjusted - a job for an experienced pro.
2 - the screen (if it's about it) has multiple layers - if one of them gets damaged then the entire screen is gone, it's impossible to fix it, it must be replaced. Find one here
http://www.tvscreenrepair.com/
Posted on Aug 24, 2010
  • Azrael SRL Aug 24, 2010
    The price for the first job, parts and labor included - around ~$200
    The replacement screen with install - around $250
    It's an old tv, nearing the end of its life - i wouldn't put so much money in it.
    Glad i could help.
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Hello, my blackberry curve 8520 has a horizontal
I have the same problem, but it's a vertical white line.  I have a BB Curve 8310.  From what I've researched on the web, it seems the LCD screen wud have to be replaced.
Feb 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Sony KP-51HW40 51" Rear Projection Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
