Question about Samsung AW0803M Air Conditioner
I am about to install this model in a basement window opening should i pull unit out of sleeve secure sleeve then install unit back in sleeve?
  • 107 Answers
That is the best method. Make sure unit is tilted to drain properly
Posted on Aug 25, 2010
Fuel filter location 08' volvo v50 1.8 petrol?
Removal & Installation
Print
NOTE The fuel filter is either on the left side of the firewall or next to the fuel pump near the left side of the fuel tank.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    Negative battery cable Fuel filler cap Fuel lines from the fuel filter Fuel filter from the bracket
To install:
  1. Install or connect the following:
    Fuel filter to the bracket Fuel lines to the fuel filter Fuel filler cap Negative battery cable
  2. Start the engine and check for leaks.
    Fig. Using an open end wrench to push the quick disconnect coupler sleeves back-5-cylinder models
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
To install:
    Fig. Using an open end wrench to push the quick disconnect coupler sleeves back-5 cylinder models
  1. Before servicing the vehicle, refer to the Precautions Section.
To install:
On these models, the fuel filter is part of the fuel pump assembly. Refer to Fuel Pump removal and installation.
May 12, 2012 | 2005 Volvo V50
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
I need the radio operating manual for a Jeep Patriot 2009 model. Where can I down load it from as the local dealer cannot seem to find a hard copy for me.
following is the procedure. u can also check ehow for more details.
  • Twist the negative cable off the terminal on the vehicle battery, using an adjustable wrench.
  • Remove the factory issue stereo. Pry off the radio trim bezel with a flat head screwdriver. Remove the four bolts on each corner of the radio. Pull the radio out the dashboard. Unplug the thick black radio antenna cable. Disconnect the wire harnesses from the rear of the stereo. Place the old stereo to one side.
  • Prepare the dashboard for the new stereo. Fit the radio installation sleeve provided with the aftermarket stereo to the radio installation kit. Feed the sleeve through the portal of the radio installation kit and bend the tabs on the sides of the sleeve to secure it in place. Feed the audio wiring of the Jeep and the radio antenna cable through the portal of the assembly and slide the assembly into the dashboard. Secure it in place with the bolts removed earlier.
  • Wire the new stereo. Connect the wiring of the stereo to the audio wiring of the Patriot, using a custom wire harness adapter. Push the connections together until they snap into place and test the connection by tugging gently on either end.
  • Plug the radio antenna cable into the alloted port on the rear of the aftermarket head unit.
  • Slide the connected aftermarket stereo into the prepared housing in the Patriot's dashboard. Click it into place in the radio installation sleeve, taking care not to trap any wiring.
  • Jan 03, 2011 | 2009 Jeep Patriot
    We have a series 90S, 2.5 gallon Shop Vac. We used it for the first time to try and **** up water in the basement. Each time we turned it on, it would shut down after collecting less than 1" of water. We...
    Remove the foam sleeve when using the unit to pick up water. The float is in there to indicate when the unit has "enough" water in it. The float rises with the amount of water and when the water reaches a certain height the float is "pulled" up into the air exhaust hole causing a change in the sound of the unit. This is the audio indicator that it is time to empty the water. If the foam gets wet with water, it closes off the air almost like the float does and the suction of the unit is reduced.
    Oct 02, 2010 | Shop Vac Vacuums
    Finding a suitable thru the wall air conditioner
    Not exactly....if you can half or more of the side vent exsposed then you will be okay...I like the side vent models because they are less prone to recycling the air...they either pull in the side and expell out the back or visa versa...
    On the total back models all the air is just pulling and pushed out the back and they are prone to overheating in some wind conditions...the air just recycles...
    Of course the main problem is that most people fail to keep their unit cleaned properly and that causes the overheating...
    Window Air Conditioners - Clean them every year
    http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
    heatman101
    Jul 20, 2010 | Kenmore Heating & Cooling
    Air intake via hose & window or intake from room only?
    Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
    Jul 09, 2010 | Amana Heating & Cooling
    Headlight replacement
    Open the hood, Turn the twist lock sleeve the surrounds the wiring harness end and pull out bulb holder. Pull out old bulb, press new bulb tab into slot, replace unit back into light housing, turn twist lock sleeve to secure to housing.
    Dont touch the new bulb with your bare fingers.
    Skin oils can heat up on the bulb and cause it to fail.
    Jan 17, 2009 | 2004 Hummer H2
    Is this the right unit? Can it be used with a sleeve?
    If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
    Jun 12, 2008 | Heating & Cooling
    Through the wall vs. window installation
    window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
    but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
    in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
    a sleeve just gives you a way to balance / attach to the outside wall
    I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
    There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
    Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
    Heating & Cooling Logo
    Top Samsung Heating & Cooling Experts
    billconfused
    Ezewudo Onyekachi
    Ezewudo Onyekachi
    Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
