Question about Hotpoint First Edition WMA20 Front Load Washer
Our Hotpoint WMA20 Washing machine is not draining, even though it appears to do a fast spin. The machine was installed several years ago and has previously worked normally. Is there likely to be a simple solution such as a blocked filter? I can't see any user-accessible filter to clean. What would you advise, please?
  • Hotpoint Master
  • 3,463 Answers
Filter is tbe found by removing lower rear cover of washer, and removing the large black hose fastened to bottom of drum, remove and clean plastic filter inside the hose.
Posted on Nov 29, 2010
Testimonial: "A service engineer dismantled the pump and found an elastic band entangled. It's useful for the future to know how to access the filter - many thanks."
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Hotpoint first edition wma20 - machine is not spinning fast enough, everything else is fine
Are your clothes coming out still wet which is why it appears that the spinning speed is too slow?
It COULD be that there is water still left in the washer which the drain pump/motor has been unable to remove. It's a common problem!
So I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 06, 2011 | Hotpoint First Edition WMA20 Front Load...
Hi we have a Hotpoint Aqualtis AQXXD169PM washuing machine that is approx 3 years old. It has worked fin until a day or so ago when taking out the washing it was still soaking wet. After investigation it...
Assuming that the pump is okay and water is draining properly,Could be the speed control module or motor brushes,normally they last around 5 years and wear out simple to fit , you could remove one from the motor to check that is not worn right down to Zilch,if these are okay then you may need an engineer,as this is quite an expensive part to fit,you could phone hotpoint they charge around 100GBP,to repair......Parts are supplied free of charge with a call out hence the £100...hope you get on ok...
Mar 19, 2011 | Washing Machines
Have put a wash on today but drum won't empty, have no idea why this has happened?
There are many reasons why it won't drain 1 the pump has gone. 2 is something is blocked in the pump. 3 the drain is blocked so won't drain. To see if it will drain turn machine on put on spin and press start if it still won't drain but making a sound like it is trying you need to pull out machine and check drain hose and drain for blockages. But if pump making no sound then the pump has probably gone and needs replacing.
Sep 20, 2010 | Hotpoint First Edition WMA20 Front Load...
Hotpoint WMA20 will not fast spin
It is rare that it would be the bearings as there would be play in the tub, it would be noisy and would probably leak. There is a small electrical box in the bottom of the machine. This is the speed control for the motor. You will also find the wireing diagram in a plastic bag in this location. You can check to see which wires require current to activate the different speeds.
I hope this helps.
Dec 28, 2009 | Hotpoint First Edition WMA20 Front Load...
Stinky grey goo in my Hotpoint WMA20 washing machine
you can only change the seal as this is a common fault with low tep washing Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Oct 28, 2009 | Hotpoint First Edition WMA20 Front Load...
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
No longer rinses or fast spins...although drum does go round slowly... My WMA 13 First Edition Hotpoint has stopped fast spin, so although the drum does go round, it does not speed up to a fast spin at...
LETS check the DRAIN MOTOR PUMP it could be clogged , open panel of washer to access inside , look for a small motor with 2 hoses connected to it , take it out , clean it , re install and try it again , hope this helps AJ
Apr 14, 2008 | Hotpoint WMA13 Front Load Washer
Hotpoint First Edition WMA20 Front Load Washer Logo
375 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
