I have a sonicview 8000HD with an ihub. The wiz config is supposed to find files and fill in ip information when you press search. { can easily open the wz but when I press search nothing happens. I have re-instaled the wiz conffig with the same results. I hope you can help me. Thanks James Heney
  • BuzzJames Aug 25, 2010
    I am trying to run the program drectly from the modem,
    I stikk have the same problem with the wiz config not doing anything.
    Ihave a lan connection with numbers a lot like yours 192.168.0.5
    I have a nano 2 hooked up that shows you the network from the modem a lot like another lan connection on my computer. 192.168.35.2 I hope you can heip.
    Thanks
    Jim Heney
    Genius:
  • 1,035 Answers
Try this troubleshooting steps. Something to check before you get started with the steps. Make sure you are directly plugged in to the first port on your router (with your computer in 1st port) and modem connection or dsl in the one furthest to left. Go to Start>Run>CMD>ipconfig
Make sure your Local IP is 192.168.1.100 and default gateway of 192.168.1.1, if not then I am not sure these steps would apply to you as well.
Make sure you have done:
Factory Default file from USB to receiver
Sys Clean file from USB to receiver
Hard reboot (back switch)
Load 206 Bin (for elite receivers only This is June 30th fix)(if your receiver is 360p-June 30th Fix or 8000hd-June 30th Fix is the correct fix file for those receivers with this step)
First step.
1. Connect iHub to receiver
2. Leave Power on, on the receiver, but turn power off from the front panel (so that the time is displayed)
3. Connect ethernet cord to iHub, then directly in to ethernet port on computer, this part is where it is tricky and you might have to wait until you see "limited or no connectivity"
4. Open up the WIZ program, click search until it displays the fields with some sort of info. Once it does, your in luck! Now you need to skip around a little for this next step.
4 1/2. Make sure Static is checked, you should now see the fields able to change settings. Make your settings match below settings.
Local IP: 192.168.1.101 Port: 1920
Subnet: 255.255.255.0
Gateway: 192.168.1.1
Operation Mode: Mixed
Make sure USE DNS is checked!!!
DNS SERVER IP: 208.67.222.222
Domain Name: WWW.SVFTAIKS.COM
Now click on Setting, if it gives you an error after clicking, click setting again until it takes. Once it does, close the WIZ program and follow on to next step.
5. Now that you can see the iHub current info and the settings, now what you want to do is check on the back of your router, this part is crucial... Make absolute certain that your PC is plugged in to the first outgoing port on the router. And now unplug iHub from back of computer, plug it in to the 2nd outgoing port on the router (the ip that the router assigns to this port should be 192.168.1.101 by default.)
6. Open up WIZ program again, and click on Search until it finds your iHub, notice that the settings should read what I typed above? If it does then continue on, if not, then go back and retry until it does!! So now that it says the settings that we want it too, we still see the v82.0 right? Lets get rid of that now.
7. Go to Start>Run>CMD>ipconfig
Now type: ping 192.168.1.101 (if you get a series of replies, we will be able to load 1.4 with no problems at all!) Thats right, you can click thanks!!
8. Now bring the WIZ program back up, and I want you to click on Upload tab, you should be able to at this point, make sure you have extracted the 1.4 bin to your desktop. and then choose that file. You should instantly notice it start uploading with little bars with pretty much no hanging at all.
9. Once it says Completed, close WIZ, then reopen it, notice a new version?
10. Thats it, that should fix the problem
Additional steps to load bin 209 (for elite users only)This is July 11th fix for all 3 receivers(latest fix). You should see Network device connect! after rebooting receiver with iHub plugged in.
Then just put bin 209 on USB stick, upload, reboot, and you should be good to setup all your settings as before - Also, you will now be able to see your IP Config menu again and able to change settings at will.
Posted on Aug 24, 2010
  • 3,083 Answers
Not sure if this will help, but I ran across this web page, and it might be of help to you:
http://www.abadss.com/forum/484-sonicview-general-downloads/108433-ihub-loader-utility-ihub-file.html
It sure sounds like a software problem to me, as you've thought, and I'm wondering if the wiz isn't that much of a wiz. I guess it could also be some glitch in the operating system, not sure. I would contact support and see if they have heard of this problem.
Couldn't find any net forums related to this problem.
Good luck, and hope this helps.
Posted on Aug 25, 2010
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
How to connect a linksys 941 phone
SPA 941 is a pixel display phone. You can configure it to work with any IP Telephony server like asterisk easily.
1. Press "Paper" Button and press "9". You ll find yourself in network settings.
2. Configure IP address, Subnet mask, Default gateway.
3. Now enter http://ipaddress in your browser
4. Choose EXT1 menu on top
5. Configure the following
Proxy: Your server here
User ID: Enter the phone number (Mostly they are phone nos.)
Password: Enter the password / Secret
Note : depends on your server config you may need to configure some extra informations. Say SIP Port, Preferred Codec, Auth ID etc.
6. Save settings
7. Happy calling.
HTH
-Karthik.
Oct 19, 2012 | Linksys SPA941 IP Phone
How configure proxy on mp114 fxs
Download your INI config file and search for ISPROXYUSED under [SIP Params] block, if is not there add the line as follows:
ISPROXYUSED = 1
Then search for ProxyIp 0 under [ProxyIp] block and if there is no line add it as follows:
ProxyIp 0 = your.proxy.ip.address, -1, 0;
This will set a unique proxy IP address for all the SIP outgoing traffic of your MP, if you wish to use more than one SIP Proxy you may want to consider setting IP address on Routing menu.
Feb 15, 2011 | AudioCodes MediaPack MP-114 FXS
I am trying to configure a Soundpoint 330 IP Phone, everytime i try and make a change in on the web console it reverts to a default! I think the phone is pointing to another config file, is there any way...
You could edit the config file in notepad or try clearing all your browser cache and history. if all this fails check to see that the config fi,le has read write permisions under its directory.
Oct 23, 2010 | Polycom SoundPoint 330 IP Phone
Wont load ihub filel.net
Verify on the website that the service is running first.. Make sure that all connections are correct and you have lights on the hub as well you can see the IPCONFIG menu in the Installation menu. If the IHUB is not connected or resets, the menu item will not appear. If the IHUB resets, it must be reboot to operate again.
Confirm what your system IP is and your router Gateway IP. Don't confuse any of the PCs in the system or a leaching user as your IHUB. Many routers include software like Network Magic. It won't see the IHUB. Once you know and can identify which IPs are being used on your system and by who, make sure the gateway IP is the same for the IHUB as the Gateway for the IHUB. In some cases the IHUB will incorrectly identify the gateway and use an incorrect IP address. This will intern create an incorrect IP address for the device.
f you find this to be the case then change the DHCP to static and correct the gateway numbers and assign an IP manually to the IHUB.
The Local IP is the IHUB IP number. Make it a number above the last IP in use on your system. Local port is the port your receiver uses so that's 80. Subnet is 255.255.255.0
For the moment say no. Change the Server IP to 77.93.75.115
DNS IP may show all zeros and that's fine. The server port is 1920 and will remain the same. Make sure now your serial number is correct and click on apply.
You should check now and make sure things are working.
Take care.
Aug 23, 2010 | Computers & Internet
Avaya assighning New static IP address after IP address conflict
The phone is looking for the calsrv ip address, which it cant see. So it is trying to "Dsicover" it.
Go to another phone and press "mute"ADDR#
You can then see the ip address information and input it into the phone that is incorrect.
Mar 04, 2009 | Avaya 5610 IP Phone
How i configer my router so i can watch my camara anywhere.
1. DHCP is enabled by default; there is no need for IP settings in LAN connection.
Open Internet Explorer and write “192.168.1.1” in address bar and press enter.
There must not be any proxy setting in the internet Explorer.
2. Following Screen will appear. Enter the Pass word 1234 and press Login.
3. Next screen is for changing the pass word of DSL Router. Ignore this for retaining default
Password by pressing ignore.
4. Next Screen is for wizard setup. Select “Go to Advanced setup” and press Apply
5. Following Screen will appear. Select “Network" on the left.
6. Select “WAN” and “Internet Connection” Tab. After filling the parameters given in the
windows, Press Apply.
7. Select “Advanced/ Dynamic DNS” and check “Active Dynamic DNS”, Press Apply.
8. Select “ UPnP” and check “Active the Universal Plug and Play(UPnP) Feature”, Press
Apply
9. Check the assignment of IP Address under WAN Information.
Your installation is completed. Browse any web site to check the successful installation.
if your problem solve then good if not find out more
send me your e-mail adders i will send you with pic configuration
my e-mail is
taki707@yahoo.com
Dec 13, 2008 | Zyxel ZyAIR G-4100 Wireless Router...
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
