Question about Samsung TX-R2735 27" TV
No colour when dvd player connected to tv
We buought a new samsung 27" flat screen tv. When we start it works properly and also we can see its color properly. But if we connect a dvd player to watch a movie we cant see its color. we can see only black and white image.
  • Anonymous Mar 21, 2014
    Don't know what you want I have described my problem
    Genius:
  • 1,074 Answers
There are two things you should look for 1 check your video wire that you connect from the dvd to the tv the the vodeo wire has two yellow connectors maybe the wire is broken .2 maybe your tv or dvd is set to pal check both push the pal button on the dvd remote and see what it does.good luck
Posted on Feb 21, 2010
  • 21 Answers
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
Posted on May 05, 2008
My samsung tv is not ok, when switched on screen is changing every 10 seconds from one colour to the other, no picture
that is usually caused by a connected device eg a DVD player with a non compliant cable. any way if you press the menu button and the menu appears ok then the tv is fine. It just means the external device/cable has go the FOCUS because its like the situation where you put in a dvd and press play or ON on the dvd player, its just the cable maybe CHEAP and be giving a FALSE signal. The Screen Is All White Black Or Another Solid Color
May 04, 2018 | Samsung Televison & Video
My Hyundai tv 74 cm The color it not show good
Nice big screen but CRTs are getting old So, if you can't set correct colors with your Hyundai it might have some serious issue with tube. Probably replacement might cost you more then a new new 27" Flat Panel. See some tutorial and info about bad color of CRT
Fix your own CRT Television Color Problem
How To Diagnose Bad CRT or LCD Monitor
http://www.electronicrepairguide.com/monitor-color-problem.html
LG M2762D 27 Inch Widescreen 1080p LCD TV Monitor Black
LG Electronics LG M2762D 27 FLATRON LCD TV widescreen 1080p FullHD HDTV...
RCA F27440 27 CRT TV
Samsung TXN 2798HF 27 Tantus CRT TV 1080i
Aug 02, 2015 | Televison & Video
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
Had to get new DVD player as old one packed up. Connected one year old Samsung television receiver LA26B450 to new Philips dvd player DVP3560K but gives no colour, only black and white. Have checked...
to put this simply ive spent almost all day advising on this exact problem have alook at my fixes and it will show you the problem but to put it simple you either have connected the wrong cables ie-- rca vs caroma the best way to fix this is to correct the setting in the output on your dvd player it needs to know what signal to send the tv ie rca caroma or hd cable
best of luck let me know if you need further help
sonic boom electronics
Dec 28, 2010 | Samsung SP42P2S Television
How do I connect the DVD player to my tv? My last DVD player had a place on the back to be able to hook in the cable along with the color wires. This DVD player does not have a place to hook in the...
What colour wires does the new dvd player have? The colours correspond with the socket that you plug them into. If your new dvd player only has yellow red and white cables then that is all you need. if they are red blue and green then you will also need to plug the appropriate audio cable into the dvd player. If you need more help please tell me the model of dvd player and the model of tv
Dec 25, 2010 | Televison & Video
I just brought a Samsung Home DVD theater system model # HT c550. I have a Samsung Flat screen TV with only 1 HDMI port. I have the cable box and a XBOX game connected already.I have been unable to set up...
hello, put your dvd player in hdmi 1 then use a scart lead for your cable box xbox usually connect to the 3 colour plug at the side of the tv if the don't work get back to me and with model number of the tv and i'll down load a owners manual and help you get connected hope it helps
regards
shaun
Dec 25, 2010 | Samsung HTC5500 Theater System
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Bought a new flat screen tv. my dvd player gives
Yes, this would be a connection problem or it may be a bad board in the tv. I would double check the connections and if they are good I would exchange the tv.
Jan 03, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Samsung TX-R2735 27" TV Logo
875 people viewed this question
Jerry Greenberg
Jerry Greenberg
