G,day ,I,ve purchased a PS50C91HD plasma TV,and I live at Killarney Vale NSW, my question is,do I need a Ditgital Set Top Box, for a good picture or the best image the TV can produce.
  • lpgrabbits May 09, 2008
    I,m an Aussie,mate- Thank you very much, Greatlyappriecated
    by an old novice movie fan, who has just got into a few new Didgital gadget,s, and running round like achicken with no head, all the best, mate.
  • 1,512 Answers
Hi lpgrabbits
You have purchased a TV that has an inbuilt digital tuner, so no worries, you get the best performance(and the extra channels) without a set top box. Just have to be sure that you have loaded up the digital channels to your preset list. Any dramas, I can help you out.
robotek... Brisvegas
Posted on May 05, 2008
  • Graeme Ross
    Graeme Ross May 09, 2008
    no worries mate... happy veiwing... you'll love the big screen :)
CANNOT GET DIGITAL TUNING - IT SEEMED I HAD IT AND NOW THE PICTURE ON THE SCREEN HAS GONE SMALLER AND NO OPTION FOR RESET IN THE TV SET UP BUTTON AND ONLY CAN GET BBC 1 AND 2? ANY HELP WOULD BE...
Hello katiebould,
Welcome, and thank you for using FixYa!
I woul recommend that you try a Set-Top Box. It appears that you were actually on the last leg of Analog TV and need to use a converter to pass the digital TV into Analog for your TV set.
You can try and find them at your local Best Buy/WalMart or check with you local TV Shop.
Here is a link to one that can be purchased online.
Set-Top Box
http://www.newegg.com/Product/Product.aspx?Item=N82E16882439001
Have a great day!
Sep 11, 2011 | Televison & Video
PN63C7000 plasma turns on but shows no image.
HERE'S THE ANSWER TO YOUR PROBLEM:
There could be a problem with your aerial or set box if there is something wrong with your TV picture or sound. Don't forget that there may be work going on at your local transmitter, or some kind of local interference.
Here's what you've got to do: Check with the local neighbours or another TV connected to a different aerial in case you are not the only person's aerial affected.. If only your TV is affected, the problem is likely to be in your TV, set-top box or aerial. If other TVs are affected, it's more likely to be caused by work at your local transmitter, or possibly the weather.
Your problem is solved. Thanks.
Jul 04, 2011 | Samsung PN63C7000 TV
I purchased a Grundig GUD1500XI2 Digital Freeview Box for my old small TV. Unfortunately it insists on filling the TV screen on 4.3 ratio by cutting off the sides of the picture. If 16.9 is selected it...
Please remember all modern Digital Set Top boxes are designed with HD LCD/Plasma TV's in mind. Their default aspect ratio is 16 : 9. The reverse was possible- LCD/Plasma allow you to change their viewing aspect ratio from 16 : 9 to 4:3 ( some models also allow 14:9 ).
You will have to return the box if it makes it intolerable for you to watch geometric distortions !!
Mar 08, 2011 | Televison & Video
I purchased yesterday a 42"
I came across this very same problem a year or so ago regarding a Plasma TV and connection via scart. It turned out to be a problem with the scart lead. Replacing the lead with an all pins connected type fixed the problem. It was caused by the TV not being given the +ve voltage on pin8 and the TV thought it was not a proper signal and shut down.
Hope that helps.
Feb 27, 2011 | Televison & Video
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Does my plasma need set top box
The changeover slated for Feb 2009 only effects those people that receive TV signals from antennas. If you currently use cable or satelite, you do not requrie a set top box. Your particular model has an HD tuner so you would be fine in both cases.
Dan
May 06, 2008 | Televison & Video
No picture on plasma
Service time! Get quickly to the retailer or service port for what ails this set...accordianman
Mar 04, 2008 | Televison & Video
Picture takes a long time to come on
Need more info on the unit.
Model, Serial # and Version # on side of unit. It sounds like you either have powersupply problems or cold solder joints in the power supply. Resoldering board may solve your problems.
Let me know, Have a good day. Jay
Jan 20, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
