Question about Fuji Cameras
Will not take a picture...I turn it on everything looks normal..when I push to take pic it turns black...no pic
  • 10,594 Answers
I need model number of your Fuji camera to diagnose possible cause of problem.
Thanks.
Posted on Aug 24, 2010
  • Shahid Electronics
    Shahid Electronics Aug 24, 2010
    Thanks for model info.
    If camera shows previously stored picture correctly but does not show live view in camera mode to take picture then it seems ccd imager chip problem and if camera gives correct live view in camera mode but does not store picture then it sounds aperture problem that is located in lens mechanism.
    Try to reset camera to set it on factory default settings then check.
    If problem does not solve then camera needs visual check by qualified local camera repair shop guy to check aperture and ccd imager chip function.
    Hope these info will help you.
    Thanks.
    I think given info is an answer to your camera problem.
I have a jvc tv , old, model no av-48wp34....turned it on hsd sound pic everything normal , changed channel, picture went 80% black , stil have sound
HI Bonnie,
If you have a good picture when it's on then it points to a dry joint on the circuit board, It is probably round the switching transformer section or the eht section but please be aware of the very high voltages stored in the capacitors and tube.
If you need any more help don't hesitate to contact me.
Regards
Barry
May 06, 2016 | JVC Televison & Video
Its as if the camera lense is not seeing, can take a pic, it shows display setting, but black no picture, even looking at pics, what can be the problem?
I'm having the same problem. Have already reset several times, changed the battery, shaken it up, turned off and on and everything and anything friends have suggested. Even used the vacuum.
Sep 25, 2011 | Sony Cyber-shot DSC-HX1 Digital Camera
When I turn on the camera, the screen remains black and only menu items appear. I can look at pics on the memory stick. Everything else seems to work.
Try pressing the button on the bottom right of the screen. It's got a little box beside it. If that doesn't work, my guess is it's a hardware problem. Try taking a picture with it eventhough you can't see what you're taking a picture of. Then see if it comes out black.
Nov 14, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Ps3 with black screen!
Yeah there is nothing to it. Just go up to your PS3 and hold down the power button untill it beeps. This should reset everything back to default on you system
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Nikon D40x camera
This setting is just showing you what part of your image that will be blown. Just use your arrow button to scroll thru other settings till your screen goes back to normal.
Oct 31, 2008 | Nikon D40x Digital Camera
Camara powers on but will not snap picture!
did you just try to press the shutter button halfway?if yes...press in all the way through...if still does not take a picture..master reset...
-press menu
-press right to go to setup
-go down to reset
-highlight yes then press menu to ok it
-turn off then on then try to take a picture
hope it will help...(",
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
Can take one picture...then screen turns black
Contact Olympus Technical Support Team This is a workshop job.
Jul 16, 2007 | Olympus Camedia D-390 Digital Camera
Cameras Logo
15 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
