Question about Hybrid Urban Mover Cruiser Bike
I have a sharper image electric cruiser and having electrical problems. looking for a service manual or electrical diagram.
Multipal electrical problem in my volvo s70
Lots to look at when you have electrical problems. You will need a factory service manual, electrical diagrams, with plug pin outs, a volt/ohm meter, and know how to use it. Follow the service manual closely. You will figure it out. First guess would be to check ground points first.
Nov 25, 2016 | Volvo S70 Cars & Trucks
I thought I was downloading a manual for the Sharper Image Select a Temp. But somehow I downloaded one of my files instead. How do I remove it?
in the internet explorer, go to internet options > general > settings
> view files , this will show you all the files downloaded in temp folder . and you can search by date .
Feb 15, 2015 | Sharper Image The Select-A-Temp 1.7L...
4.0 2H HJ 75 land cruiser
diagram of what, inside, outside, mech, vacuum, electrical or what?
complex it is. EFI?
alldata.com, has it
so does the FSM , ebay buy use FSM , factory service manual.
Jan 21, 2014 | 1989 Toyota Land Cruiser
Sharper Image Desk Lamp S1412. I need a manual. Lamp has quit working. Doesn't appear to be the bulb.
I have the same lamp with similar problem. I suspect the problem is with the ballast or starter, not bulb or switch. Ballast likely in the base. I'm searching for a replacement ballast.
Jul 03, 2010 | Kitchen Appliances - Others
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
Hissing noise from Ionic Breeze
The hissing noise is caused by the 5000-volt grid wires arcing. If you look inside the unit closely in the dark, you'll see blue electrical arcs -- these generate the hiss.
The arcing is caused by deteriorating grid wires. If you've cleaned it as well as you can, and it still hisses, it won't be long before it fails.
With Sharper Image out of business, don't know if there is still a repair service for these units.
Charlie
Aug 28, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Missing battery charger
I have two chargers for mine willing to talk 616-308-3566 ,  This is the electric cruiser by sharper image?
Apr 04, 2009 | Cycling
We have a Human Touch Sharper image chair purchased online from Sharper image. The remote control has come detatched from the electrical wiring. It has pulled out. Our electrician suggested that we ask if...
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Hybrid Urban Mover Cruiser  Bike  Logo
357 people viewed this question
Top Hybrid Cycling Experts
John Egan
John Egan
Are you a Hybrid Cycling Expert? Answer questions, earn points and help others
