Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
HDD Error My HDD was happily recording from the TV when it froze and now all I can get is HDD error and a message that says the HDD info is incorrect. ANy fixes for this?
  • videoteknix Jun 10, 2008
    my DVR 530H gave me an error message saying "HDD ERROR" and switches to DVD mode and i cant even watch a dvd cause of it aswell. :(
    Can i take the hdd out and format it on my pc? and then install it back to the unit?
  • Anonymous Aug 27, 2008
    I have the same problem on my Pioneer DVR-530H-S, which has been running ok till few days ago. Any idea?
Since my last post, I have rectified the problem.....
1) I opened the unit to find a seagate HDD
2) I downloaded the Seatools in dos format and burned the image on to a cd rom
3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
Here are the links
http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
I hope you fix yours XD
Posted on Dec 07, 2008
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
No bootable device found.try reseating hard drive,error code 0141
Make sure you fixed the HDD properly..In some cases you need to push a little harder. See if any pins had been bent, if so straighten it, without breaking it.
Jun 07, 2009 | Dell Inspiron 1525 Notebook
HDD Error!
Take it to a camera store or to a Best Buy store and see if the hard drive has a problem with it such as a bent recording head.
Did the hard drive format completely?
Nov 26, 2008 | Video Cameras
Cannot copy files Parameter Incorrect
most likely the issue is that your trying to copy files over 4gb to fat32 disks, and this causes the parameter incorrect -issue. Try formatting the drive your copying to ntfs, this can handle +4gb files.
Nov 11, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Sony dvd recorder as hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Nov 11, 2008 | Sony Televison & Video
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Hard Disk error
power up your dvd then you you disconnect from the power cord.wait a few mins like 5 mins then you plug it in back and power it up if that does not corect your problem.the strip that leads to your dvd lens needs to be changed.or the micro chip that controls the hd needs to be changed.however take it to a tech.
Feb 19, 2007 | Pioneer DVR630H DVD Recorder
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
923 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
