On the screen of the machine indicates "TONER FILTER EXCHANGE OF TIME" need to know if is possible to solve this. Thanks: Ulises
  • 11,800 Answers
The filter for the toner must be replaced. Since you didn't provided the model of your printer (most likely a Konica-Minolta) all i can say is that the filter is somewhere on the back on the right side. After you replace it you must reset its counter .  The exact procedure for your model is in the manual - you must have service level access to it.
If you don't know how to do that then call an experienced repairman, service level access is very dangerous in unknowledgeable hands.
Posted on Aug 24, 2010
How to solve add toner see instruction front cover to replace toner ricoh mp2000
If you just add toner and it just keep saying add toner. open sp mode.
Press: Clear modes>1-0-7>Clear/Stop> SP2 x x x- Drum > 214 -Developer Initialization>Exectute and wait.
please rate. thanks
Dec 09, 2014 | Ricoh Aficio mp2000 Copier Machine
Copier stays on please wait after resumig one job
There are two possible solution, the first is that the Drum Potential Sensor is damaged and need to be damaged, the second is that may the NV-RAM is damaged and need to be replaced. This two possible problems need to be solved by a experienced technician. If this question is posted by a user, than the only thing you may check is do the PCU Harness is connected good. That harness is located under the touch screen, when you will open the front door, than putt the toner bottle in position for replacement. right under the touch screen behind the toner bottle you will see two harness re-connect them and see do the problem will be solved if is not than are the two other possible solution i mentioned in the start of the answer. good luck.
Nov 12, 2014 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Dispose of used toner error.we already clean the toner bag.and also the sensor behind it.and also check the alignment the area.withih the toner.what is the other way to fix this error.or maybe this have...
399 (0)
start 6 (2)
Most commonly the waste toner bottle is located on the front of the toshiba copier, however, on certain models they are located on the back left side of the machine. On the right side of the machine is toner bag filter, which often appears to be the waste toner bag as it possessed waste toner and developer. If you are sure you emptied the proper container, then I suggest resetting the counters in service mode.
The process:
1. Turn machine off, press and hold "0" and "8" simultaneously while you power the machine on, after about 15 seconds the service mode will display, press "399" and then press "0" and then "set."
2. Turn off machine, press and hold "start" "6", then after the service mode loads, press "2", then reset the number to 0 by pressing clear.
3. Reboot machine and see if error clears.
-David.
Oct 31, 2010 | Toshiba Office Equipment & Supplies
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
Feb 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine. to supply the toner always do this, 1-insert the new toner bottle in the toner section and close the cover. 2-Press "Utility/Counter" Button. 3-click on "USER CHOICE" or "USER SETTING" 4-click on "Toner Supply" 5-Toner bottle will start moving and hence the error message will not appear again.
Oct 27, 2009 | Minolta bizhub 200 All-In-One Printer
How to reset toner drum for the oki c5510 mfp?
. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | OKI C5510 MFP All-In-One Led Printer
Error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
THIS WORKS ALWAYS
Jan 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Toner sensor error
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Feb 11, 2008 | OKI C5200n Laser Printer
Writing in grey scale
Make sure that in the printer driver that print the text as gray scale isn't checked and that the toner saving mode isn't on. failing this you may have a faulty machine return it to the store and get an exchange.
Hope this helps
Thanks J
Jan 13, 2008 | Samsung CLP 300 Laser Printer
Canon Error Wrench pops up on screen.
drum unit life out or toner unit life out, u try exchange the drum or toner unit to reset the chip
Jan 30, 2007 | Canon imageRUNNER C3200 Color Printer
k24674
jasbo
jasbo
