Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet front load washer, model GHW9100LW. Sometimes the water will not drain after a load is finished. This only happens sometimes. When it does, the autolock does NOT work and we end up dumping water all over when we open the door. Also, sometimes the washer will fill up with water when it is empty and turned off. Since we leave the door open to prevent the mildew smell, we end up with a flooded floor. (This problem seem similar to the person with the model GHW9150P so I suspect a possible faulty inlet/water valve). I am trying to get the bottom panel off to check, but am having trouble getting it off). Thanks, Jim
  • 1 more comment
  • jvogtfamily Aug 24, 2010
    Thank you. If the valve was stuck open, wouldn't it continue to fill? This only happens sometimes and often when it has been off for over 24 hours. Very irregular??
    I don't have any problem draining the water. I just turn on the drain cycle. I'm still having trouble getting that panel off. There isn't much room to lift it and it's still catching near the top.
  • jvogtfamily Aug 29, 2010
    The washer has not filled with water since I unplugged it a few days ago so I'm not sure if it is the inlet valve or not. It is difficult to troubleshoot since the issue occurs infrequently, but is a real pain when it does!
  • 5,911 Answers
It sounds like you may have a combination of two problems. First, the no drain issue. This could be the result of a clogged or restricted drain line preceding the drain pump, a drain pump that has accumulated debris and needs to be cleaned, or a drain pump that is failing. The following link explains how to access the pump the check the pump and clean:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
On some model washers there is no screw off cap on the pump and you will have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Removing the inlet hose for inpsection is recommended on all these washers just to ensure there isn't anything lodged in the line. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. There is usually an error code on the front panel display that accompanies a drainage issue. A "SUD" error can often occure in conjunction with any error code due to air being detected in the drainage system. This can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The second problem of the washer filling when not in use can be caused by either a water inlet valve not closing properly, or a pressure switch malfunction. The following link explains how to determine WHICH component may be causing your problem:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
More than likely, your suspicions are correct. The problem more commonly turns out to be a water inlet valve problem. I have inlcuded the steps required to replace the either component, if required.
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Aug 25, 2010
  • Jeff Rockwell
    Jeff Rockwell Aug 31, 2010
    The inlet valve has solenoid controlled diaphragms inside that control the turning on and turning off of the water flow. If one of these solenoids does not seat properly when closed, it can leak by, causing the gradual (and almost undetectable) filling of the wash tub over night. You will usually see water trails marks around the door bellow where the fill tube is.
    Another potential cause is backflow coming from the drain line. This can occur if the drain hose is not high enough off the floor, or if the top of the standpipe is sealed closed and not providing a proper air gap.
    The steps required to remove the lower toe panel to inspect the drain pump are include din the second link I provided you. If youare having difficulty trying to access the screws, you can prop the front feet of the washer up with a 2x4. Once the screws are removed, the panel will drop down, then come off. If the panel sticks, you can lightly tap on each side to knock it free.
    President:
  • 1,554 Answers
You can drain the water by pulling the drain hose end from where it is installed and draining the water into a basin. Position the basin as low as possible to extract as much water from the machine.
The water inlet valve is likely stuck in the open position when it fills when the machine is turned off.
The bottom front panel can be removed by removing the three screws securing it to the bottom front edge of the washer then lift the panel slightly and pull it forward.
Posted on Aug 24, 2010
  • Jahn27
    Jahn27 Aug 25, 2010
    Then once the screws are removed, pull the bottom of the panel forward then down..
  • Jahn27
    Jahn27 Aug 30, 2010
    The inlet valve is is getting stuck intermittently. Replace them to get rid of this problem. It is part number 8181694 and costs about $50.
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: During washing cycle it stops and beeps with the l...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Model # GHW9100LW on final rinse and spin water remains in washer, door locked and humming sound comes from machine....pause/cancel will not unlock door or start new cycle... what might be the problem?
Sounds like the pump is trying to drain the water but something is clogged in it or the pump itself is bad. Door wont unlock if machine thinks there is water inside. Remove front lower panel. pump is in center. Unscrew cap and remove attached filter. Be prepared for water to come gushing out once filter is removed. Clean filter and reinstall. If problem persists then the pump itself needs to be replaced.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 02 whirlpool duet GHW9100LW?
unplug for 5 minutes then plug back in see if it resets itself,also check the door switch on inside of the door on washer make sure that has a clicking sound,sometimes on some models if the door switch goes bad it will not spin or drain,let me know,thanks-mike
Jul 26, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
