Question about Mitsubishi WT-42311 42" Rear Projection Television
What is the going price for a power supply on this brand T.V. and how can I be sure its the power supply?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If the power light comes on when you attempt to turn the set on and the goes off, do this:
On the front of the set press and hold both the Menu and Input buttons for at least 5 seconds and then release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 24, 2010
HP P6000SERIES
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
Feb 21, 2013 | HP Computers & Internet
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply"
Feb 09, 2013 | HP Presario Computers & Internet
Having problems with Bestec ATX-300-12z power supply.
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Parts list for a 667-L32T18-20
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. UNless this power supply is redundant - Appears to be standard<------
Sep 28, 2012 | HP (D9387-69015) (D938769015) 256-Watt...
Charger price
It depends on the model of your laptop and what brand the power supply is. Also if you get an original power supply, generic, or a good name brand but not original. Targus makes good universal power supplies but they can run well over a hundred dollars. I have purchased generic for older HP or Dell on ebay for as little as 8 bucks including shipping. Check eBay and put in your model number and the word power supply and you will see what you might have to pay.
Hope this helped... Dale
Apr 21, 2011 | ATI Computers & Internet
Got my hands on a Panasonic th-42px75u 42 inch but it won't turn. On is it worth fixing and how much would it cost thanks
The tv can be fix about half of the price of a new one.This tv brand and model known to have alot of power supply board issues.The price about between $500-$550 Tech. replaced tv with a new refurbish power supply board replacement or troubleshooting and by replacing components parts on the power supply board.
Dec 07, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Can you advise me of a suitable replacement for my psu which as stopped working. The psu fitted is fsp400-60mdn which i cannot locate a new one.Any advice would be very helpful Phil.
Unless this is a proprietary power supply design (special type case, custom-made equipment, oddball power connectors, etc.) you should be able to use any ATX replacement power supply with a suitable output rating.
I'm guessing from the number you give that the one you have now is a 400-watt supply. You can put in a higher-rated one with no trouble. They're all very close in size and have standard mounting holes, and excess capacity won't hurt anything. In fact, since under-sizing the power supply is often why they go bad in the first place, putting in one with greater capacity is usually a good idea. There's very little difference in price for the higher power ones.
Most supplies will have enough connectors to work with your motherboard and drives. Just check the specifications to be sure. There are so many sources and supplies available that I won't try to recommend a particular brand. I've used many and they all seem to work just fine.
Good luck with the repair, and thanks for using Fixya!
Mar 27, 2010 | Computers & Internet
I need to buy a power supply hp dc7700 and get it shipped to friends in africa (benin) what is the best way
Try going to hp.com and buying it and shipping right from there or while there check the weight and get shipping prices from post office and ups. Compare your prices and go the best way. You have to make sure they will ship where you want. I can not give you prices due to the fact I do not know your location and the shipping weight. Sorry hope this helps you and good luck.
Oct 10, 2009 | Computers & Internet
Brother 2820 power supply
YOU MIGHT TRY GOING ON THE WEBB AND TYPE IN PARTS FOR BROTHER MACHINES. ONLY BROTHER SERVICE CENTERS THAT ARE AUTHORIZED CAN ORDER FROM BROTHER. GOOD LUCK BROTHER SR TECH
Dec 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Power supply
Not sure what you requesting as information but to install a power supply is easy (make sure it's not plugged in obviously). Take off the case...it's right there. Unscrew from the outside to remove and install new. One word of caution...I am not a big fan of E-Machines "past"....motherboards and power supplies were (are?) major failure items with these machines. If you wish to know what supply to use check what you have and then go to pricewatch.com to find one....note, it need not be the same brand (preferable probably) but it does need to have the same dimensions and wattage. Trust this helps...Tango
Jan 18, 2008 | E-Machines E-Machine Power Supply 230W ATX...
Mitsubishi WT-42311 42" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
