Question about Zanussi Ovens
My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
After isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
Posted on Aug 24, 2010
Oven has stopped working on zanussi zbf 360
Heating element is probably shot. Turn it on....does the element glow orange????
Mar 13, 2012 | Zanussi ZBF360 Electric Single Oven
My zanussi FM9232 fan assisted oven is not heating up, the fan is working
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Nov 04, 2010 | Zanussi Ovens
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi oven not heating
The fan element was not working, bought one on ebay replaced it works ok now. Fairly easy to fix remove inside back cover, 4 screws, you will see the element remove 3 screws pull out element pull off 2 connectors careful not to lose the wires back through the holes. replace in reverse order.
Jul 12, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi zbf 760 (9 yrs old now)
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
403 people viewed this question
Top Zanussi Ovens Experts
ashburton
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
