I have a BEKO WMA 520W machine and when I turn it on it switches to wash mode, the drum fills with water and then spins once. After a short while it spins once, pauses, and spins once again. This continues for several spins and then it stops completely with the Start / Cancel light flashing and the Wash light on. Is it possible to resolve this as I have some clothes dyeing in the machine at the moment?
I am having the same fault, please let me know if you find the cause and i shall do the same. having no luck online so may have to get a 'man' out!
Posted on Sep 04, 2011
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Beko wma 510w will not spin
HI,
Try These
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion........
Jul 22, 2009 | Washing Machines
Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Apr 29, 2009 | Washing Machines
Beko Washing Machine starts program, spins once then stops..
this is joyce
Go to the webb and download a manual to your washing machine if you are going to work on it yourself but if not I would suggest you call a techn. to look at it, sounds like problems.
thanks,
joyce
Feb 06, 2009 | Washing Machines
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko 520w wasing machine
Hi see the last video on this it will show you test mode or if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
