Question about Apple MacBook Air
My husband got on my Macbook Air and pressed command + and a bunch of other stuff. Now my page won't stay still. It floats around as I use the mouse. The whole page moves.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
What you have done is accidently magnified your screen slightly. To correct this hold down your ctrl key and move your finger on the track pad to the back of the track pad. Failing this restarting your MacBook Air should reset the screen to the default view. Hope this helps.
Posted on Aug 24, 2010
Testimonial: "Totally solved the problem!"
  • louise_putma Aug 25, 2010
    My wife misunderstood the problem. It turns out I hit control-option-plus which magnifies the page and lets you move around to see various parts of the screen. In order to correct this all we needed to do was depress control-option-minus. Thanks for you help though. I was amazed when rebooting did not solve the issue!
Hpw to reset macbook pro
  1. Turn off your Mac (if it isn't already off).
  2. Hold down these four keys right after you press the power button: command+option+P+R (that will reset the PRAM).
  3. Keep holding down those four buttons until your Mac restarts and you hear the second startup chime.
May 28, 2014 | Computers & Internet
Apple MacBook Air Notebook
okay going to have a bash at solving this but it's a little hard based on your description. I'm guessing this has Mavricks operating system installed.
  1. Choose Apple menu > System Preferences, click Dictation & Speech, then click Text to Speech.
  2. Select the "Speak selected text when the key is pressed" checkbox. By default, speaking is enabled when you press Option-Esc. To choose a different key, click Change Key, press one or more modifier keys (Command, Shift, Option, or Control) together with another key, then click OK.
  3. To have your Mac start speaking, press the specified key. To stop the speaking, press the key again. If text is selected when you press the key, the selected text is spoken. Otherwise, available text items in the current window are spoken; for example, if Mail is the current window, an email message is read. If no text items are available, you hear a beep.
    So based on what you have described you have already found this option and set the change key to "command" + "e"
    Try rebooting then going to the text to speech option and attempt to set the key combination you want it to be. If this fails to change then try resetting the P-ram which should set it back to the default.
OS Mavericks Reset your computers PRAM
Mar 05, 2014 | Apple MacBook Air Mac Notebook
How to factory reset
command + R goes into recovery mode and should let you reinstall fresh.
Nov 24, 2013 | Apple MacBook Air
MacBook Help
To create a new folder on the desktop right-click on the mouse and select New Folder from the drop-down menu.
If you do not have a mouse connected, press the control key while clicking the desktop background, and select New Folder from the drop-down menu. The folder should appear near the area of the desktop you clicked with 'untitled folder' highlighted in light blue. You can now type a name for your new folder. Press return/enter when you are done naming your folder.
Apr 29, 2013 | Apple Macbook Air 11.6" Laptop Mc505ll/a...
How to get the new macbook air to install Lion from Apple usb drive? When trying to install it from the usb drive, it gives an error on the screen. Is there any way to get around that?
Are you pressing and holding the Command-R keys down when you turn-on your Mac in order to get it into recovery mode?
Take a look at this help page for complete instructions: (click here)
Feb 07, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Lap top won't come on
Follow the steps below and it should solve your mac problem..
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the fluorescent pen computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the PowerBook G4 Battery 15" power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter,learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the sony vgp-bps13a/b battery power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the sony vgp-bps13 battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
  10. If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with either an Apple Retail Store or an Apple Authorized Service Provider.
Regards,
Ron
Jun 02, 2011 | Apple 13" MacBook Notebook Computer ...
My MacBook Pro is unresponsive. I can move the cursor around, but when nothing happens when I tap the touch pad.
If this is a brand new macbook and you have not been familiar with them before....be aware that the whole touchpad is clickable by pressing it down. You can also go into your settings, under the mouse applet and choose to enable the tap to click rather than pressing the button.
Mar 11, 2011 | Apple MacBook Pro Notebook
Will not load up or take charge
Try removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
If that doesnt work try this:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Mar 01, 2011 | Apple MacBook Air
2004 Honda CRF 150 F won't stay running
Hi, Smiley1961 and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
more help with the 150r please won stay running
Brand new CRF150 won stay running
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
May 09, 2010 | 2004 Honda CRF 150 F
I can't get the mb397g/a working on my apple HELP Pz
Try this procedure with the Macbook Air SuperDrive
and then click the Apple link below to follow the remaining recommended steps with for troubleshooting your Macbook Air SuperDrive.
Here are some steps you can try to resolve the issue:
• Make sure your SuperDrive is connected to your portable.
• Properly shut down your Macbook Air
• Once it is is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook to start up.
Apple Support Link:
Troubleshooting the MacBook Air SuperDrive
This process is supported by Apple, but if it does not work, just let me know.
Regards,
-Terry
Oct 30, 2009 | Apple MB397G/A MacBook Air SuperDrive
Apple MacBook Air Logo
101 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
