Question about Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER
Brand spankin' new Master temp 400 NG,won't heat past 77° spa is set at 101°,pool at 88°, does heater pool/spa temps have to be manually set to max(104 i assume) for intellie touch to control, seller and installer have failed to return homeowner calls, i have now been called in,haven't got a manual for Pentair heater,
  • 366 Answers
If the intellitouch is properly wired to the heater, it should all be automatic and you should be able to control it all from the remote.
there should be three wires connected to the circuit board behind the manual control on the heater (labeled "POOL", "SPA", "Common"). Those are the wires that the intellitouch uses to communicate with the heater.
You can download manuals from the Pentair website.
www.pentairpool.com
Posted on Aug 25, 2010
H:ow can I get my pool heater to stay on?
Is your heater giving you an error code? When it shuts down, which light is on, "service system" or "service heater"?
Aug 24, 2014 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
My pentair spa won't get above 88 degrees
possible bad temp sensor or heater not set high enough using control unit
Jan 19, 2014 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
How do you initially start the heater
turn button to on if control on unit make sure heat enabled
Nov 26, 2013 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Heater will only go up to 89 degrees.. using the remote. do i need to set the temp at the main heater
The temp at the heater should be set to maximum when using a remote. The remote can only go as high as the thermostat setting on the heater.
Apr 10, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Pentair 400 2 yrs old won't heat spa to 98 degrees F.
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 18, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Logo
326 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
