Question about Brady BP-THT-600X+ Thermal Label Printer
I am trying to find a printband for a Brady THT 2034 printer...is this actually a Zebra model that has been rebranded?
  • 96 Answers
In the heading it says Brady BP-THT-600X+ , but in the comments it refers to a Brady THT 2034.
The THT600X+ is zebra, The THT2034 is datamax. I have printheads for both. www.clearprintsolutions.com
Posted on Oct 14, 2010
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
Where can I download the ICM or ICC color profile for the Zebra p330i printer?
Colour calibration is always a bit hit and miss with these. You can get big variations between screen RGB and the YMC that is actually printed.
Try zebra.com in the downloads you can find developer manuals that may aid you. Or contact Zebra directly via the site.
Oct 11, 2010 | Zebra P330i Thermal Card Printer
This is an old post but i still need help!! What does a Polaroid p85igc card printer use for a full color ribbon? Zebra p330i ymcko ribbon won't work
Right, zebra/eltron made the P310 printer before they started using smart ribbon. They also made the same printer as the J310 for Javelin and the P75 for Polaroid. These all ran on the same ribbon. Then there were the first "i" series machines the Zebra P310i, the Javelin J310i and the Polaroid P75i. These all ran on their own respective i series ymcko ribbons. Now here is my theory.... The new Zebra P330i runs on the same ymcko ribbons as the P310i and the Javelin J330i runs on the same ribbon sas the J310i. Don't know where the model number came from but the Polaroid P85igc is the same as the 330i printers. It therefore stands to reason that it will run on the same ribbons as the older P75i printer.
The YMCKO ribbons for the Zebra are coded 800015-440 for 200 print rolls, 800015-540 for 350 print rolls. I have seen a picture of a ribbon with 800015-540POL on it advertised for the Polaroid but cannot find anyone to sell it. I can find however a few US references to a ribbon for the P75i One is linked below. It may be worth a go if you get desperate. //www.identisource.net/pd_3151.cfm
The other alternative, as the machines are essentially the same, is to change the motherboard so the printer thinks it is a Zebra or Javelin and then buy much more readily available ribbons. We can swap the board for you but as a spare they are just over £400 incl VAT. YMCKO ribbons would only be around £30 for 200 image rolls, thats the genuine stuff not the knocked of rubbish that's around. www.pci-solutions.co.uk I shall investigate to make sure we can't "rebrand" the printer by changing its firmware, but I doubt if it will be that easy.
Aug 29, 2010 | Office Equipment & Supplies
Brady 600x Plus II Date Code Is Off
mmm...Maybe try updating the firmware. That printer is a Zebra Z96XiIII Plus printer. Zebra made a change in their code for the onboard clock in version 60.13.0.5 See if you have that version and if not, you can to to www.zebra.com and download firmware for the printer.
Hope that helps !
Apr 26, 2010 | Brady BP-THT-600X+ Thermal Label Printer
Brady ID Pal. Display says:
Brady printers have a sensor that reads information from the cartridge. The printer will not work if a connection cannot be made to the cartridge.The most common cause of failure is in the cartridge and switching to a different cartridge usually fixes that problem. Having the same problem with two cartridges is starting to indicate there is a failure in the printer, although it is possible (but not likely) to have two cartridges in row fail. A good first step is to be sure the printer is clean. If that doesn't work you'll most likely need to send your printer in for repair. A good source of free tech. support for the Brady ID Pal is Graphic Products. They even help people who are not their customers, They also do Brady printer cleaning and some repairs. They have an online for for requesting tech. support located at: http://www.graphicproducts.com/request-support.php or you can call 1-888-326-9244.
Feb 08, 2010 | Brady ID PAL Thermal Label Printer
Brady 300 mvp displays "Ribbon in" warning. Whats does this mean?
I've got the same issue. This means the brady machine is configured for direct thermal transfer (no labels in the machine). Press setup, use the - and + buttons to scroll to direct transfer. Again, press select and again use the plus or minus button to select thermal transfer (labels in the machine).
I must say that the setup menu is tricky. If a password is needed, that's another story. Not impossible, but you have to know how to use the label maker, which I don't . I'm unable to remove the flashing errror message.
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/z-rzseries-ug-en.pdf
Dec 21, 2009 | Brady Office Equipment & Supplies
Eltron 2844 CTP Printer on Ubuntu
I got it working by selecting the Zebra manufacturer, EPL2 driver.
Mar 12, 2009 | Zebra LP 2844 Thermal Printer
How do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
132 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
