Question about GE Profile DPSB620ECWW Electric Dryer
Dryer will not get hot,but everything else works
  • 6,784 Answers
Hi. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer or on the actual heater chamber or blower housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Posted on Aug 24, 2010
Will not get hot
If it's a gas dryer, check the thermal fuse, gas valve solenoid, igniter, element, flame sensor, high limit thermostat, or cycling thermostat.
If electric - check the heating element, thermal fuse, or thermostat.
Overall, dryers, specifically electric dryers, are very easy to work on - youtube has some great videos too.
Feb 19, 2014 | Samsung Dryers
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Dryer does not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 13, 2010 | Crosley CEDC392JQ Electric Portable Dryer
Dryer does not get hot/warm. everything appears to
If you have a gas dryer...
If your dryer is electric..
heatman101
Apr 15, 2010 | Kenmore Dryers
Tumble dryer will not get hot. Says Filter needs cleaning but I have thoroughly cleaned everything and it still will not get hot. Help!!
Sometimes when the dryer exhaust vent is clogged, it causes the dreyer not to work properly. If you have cleaned both the filter and exhaust tube it may be the heating element itself that is causing the problem.
Dec 07, 2009 | Candy Dryers
LG dryer will not get hot
ur heating element is broken..order a new one, out it in, and presto!
Oct 11, 2009 | Dryers
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
My space saver dryer will not get hot ,everything else works fine
If everything else works, but not heating, than the problem is either:
Clogged air ducts
or
Heating element needs to be replaced.
Jun 05, 2009 | GE Spacemaker Washer and Dryer Electric...
Frigidaire dryer problem
The vent duct length's sound fine.
Have you confirmed that the heater element is working? You don't mention whether the unit get's hot.
If it get's hot, then suspect the thermostat, or the overtemp stat.
Also, be suspect that users are overloading the dryer.
Also make sure that you feel a strong blast of hot air discharging at the vent end, with the washer/dryer in place.
Check that the vent grills inside of the dryer are clear.
Reply back and I can help you further.
Feb 03, 2009 | Frigidaire Dryers
GE Profile DPSB620ECWW Electric Dryer Logo
29 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
