Question about Franklin Industries FWC35 Compact Wine Cooler Side by Side
Vintage select franklin industries wine cellar mod lwc8t looking for parts
  • 87 Answers
SOURCE: Replacement Parts
Would suggest you try a distributor for this cabinet as sometimes they have more leeway with the supplier. Looking through sites would suggest someone like BeverageFactoy.com may have a route to the spares youre after. Hope this helps.
Posted on Feb 08, 2008
  • 32 Answers
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I haven't seen the unit you refer too but it sounds like many others that I have seen. The white stuff is heat transfer compound as used on CPU heat sinks, DO NOT WIPE IT CLEAN, if you have then it will need replacing. Check the fan is running at full speed to cool the heat sink that the plate is attached to. If there is no fan then there isnt much else that can be wrong with it apart from the control circuit, but that seems to be working as you say the plate gets hot.
Posted on Mar 19, 2008
  • 7 Answers
SOURCE: Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
milten1
  • 1304 Answers
SOURCE: compressor locked on Franklin FWC36 wine cooler.
you might be able to get one at the junk yaqrd or dump
its a relay overload on the compressor
look back at the compressor
there should be a block on one side that the relay and overlaod
go to repair clinic they sdhould have what you need
Posted on Oct 07, 2009
  • 288 Answers
SOURCE: My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Posted on Nov 27, 2009
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
    check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
    hope this helps.
    Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
    Can manuals and parts be ordered for Everstar wine coolers, HDBC36iD is the model. Thanks, Dave
    Im sorry franklen indust everstar wine systems are very hard to get parts for also the manual Not a very good unit eather according to reviews
    Dec 09, 2009 | Refrigerators
    Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
    Wine Refridgerator - Class Action Lawsuit
    Franklin Industries (Franklin Chef) has filed for bankruptcy protection as of 9/11/09:
    http://www.franklinchef.com/important.html
    Looks like we are out of luck
    Sep 09, 2009 | Franklin Industries FBC360D Beverage...
    Koolspace 600 Problem
    You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
    Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
    Replacement Parts
    Feb 08, 2008 | Franklin FWC100 Wine Cooler
    Franklin Industries FWC35 Compact Wine Cooler Side by Side Logo
    255 people viewed this question
    Top Franklin Industries Furniture Experts
    Dan Webster
    Dan Webster
    John Tripp
    John Tripp
    Are you a Franklin Industries Furniture Expert? Answer questions, earn points and help others
