Question about Janome Memory Craft 9000 Computerized Sewing Machine
I just bought a memory craft 6600 the thread from the bobbin keeps looping on the top fabric? When I change the tension number it just gets worse Help
    Genius:
  • 1,788 Answers
Check your threading, especially your bobbin because usually looping on top means the bobbin is not set right, Read your manual,
Posted on Aug 24, 2010
I can't get the tension right on my Janome DKS30 sewing machine. I can operate a machine but I am quite a novice. My machine is 9 months old and I have used it less than 20 times. Can you please help?
Sounds like your top tension is too tight. You may find it helpful to join a FaceBook sewing machines group to get further help. Happy Sewing!
Dec 30, 2016 | Janome Sewing Machines
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Adjust thread and bobbin tension
These are the instructions in the manual:
Adjusting the Thread Tension
Balanced thread tension:
Small amount of the needle thread shows on the wrong side of the fabric.
When the needle thread tension is too tight:
The bobbin thread shows on the right side of the fabric. Reduce the tension by turning the tension dial to a lower number.
When the needle tension is too loose:
The needle thread forms loops and the stitches look shaggy.
Increase the tension by turning the dial to a higher number.
However, if you have recently changed the needle check that it is pushed right up in the slot. Other thing that springs to mind is making sure that the bobbin thread is correctly placed in the bobbin, and that the chamber is not full of lint and threads.
Feb 06, 2015 | Janome Memory Craft 5700
Why is bobbin thread showing through on pattern
you need to loosen the top tension. if you notice the tension is too loose on top and bottom at the same time then go ahead and tighten the bobbin tension a small amount. then you can adjust the tension of the top. if the top thread tension is too tight the thread from the bobbin will penetrate through. the opposite is true. if the top is too loose then too much of the top thread will penetrate the fabric underneath. remember to get the tensions between the top tension and bobbin tension equal so the knot will end in the middle of the fabric.
Nov 14, 2014 | Janome Memory Craft 9000 Computerized...
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
Sir I am owning a Janome Memory Craft 10001 but recently it's not working properly in ordinary sewing mode the top side of the fabric the stitch looks okay but underneath it is loose and while embroidering...
Usually If the underneath is loose it is the top tension that is the problem. If it is the top stitching that is loose it is the bottom tension. Hope this helps.
Jan 24, 2010 | Sewing Machines
Noise from bobbin case on new Janome 4020
Check the bobbin to be sure it is inserted correctly. When you pull on the bobbin thread the bobbin should turn to the left(orcounterclockwise). If it doesn't, the thread will come out of the bobbin tension and give you loose stitches on top of the fabric. It will also make a noise because the bobbin is bouncing up and down.you will need to readjust your tension again.
sewman7
Dec 22, 2008 | Janome Memory Craft 9000 Computerized...
Tension problem
For Staight Stitch.
Ideal
When adjusting top thread the Higher the number (on the little wheel) the tighter the top thread.
Results depend on
Stiffness and thickness of the fabric, number of fabric layers and type of stitch.
Are you using paper or a plastic bag or pellon under the fabric? This gives a smoother surface for embroidery (on the reverse) and you can cut it away after the design is complete.
Susan
Mar 18, 2008 | Janome Memory Craft 3000
Janome Memory Craft 9000 Computerized Sewing Machine Logo
191 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
