Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
I haven't used my mower in a few weeks. It worked fine before, and now won't start. I can't really tell if it's turning at all, or if nothing is starting to begin with. It look a bit low on oil, but I didn't think that this was my problem. The mower itself is less than a year old. Any suggestions?
  • 755 Answers
You might have an accumulation of water in the fuel tank/carb.
Drain them both and make sure you put clean fresh fuel in.
The gas can might be contaminated too so be watchful.
Check your spark plug too. Remove it and make sure it isnt water or gas fouled. *(wet and not sparking) A fuel fouled plug usually needs replacement. Water...not so much.
Good luck and be careful!
Posted on Aug 24, 2010
Tried charging john deere battery no good after 4hrs.whats up
Walt
Does this mower have a Briggs and Stratton engine with overhead valves? If so, (and this will sound really weird) you need to adjust the valves. After a few hours of running, the intake valve will go out of adjustment so the decompressor won't work. It acts like the battery is dead when this occurs.
Mar 24, 2014 | Garden
I have a MTD yardman yardbug riding lawn mower. Its a 8.5 hp engine. Model: 13b-325-401 year:2000. It will not start, I turn the key and it sounds like its trying to start, but the belts underneath the...
check that you can turn the cutters by hand . I suspect that the bearings for the cutters may have seized up from the wet grass causing them to rust up
Jun 02, 2013 | Garden
Husqvarna YTH20K46 no power. HELP!
Not turning off sounds like an ignition switch problem. Not starting - then I think you should check the Low Tension side of the solenoid again to make sure there is current from the switch. If the solenoid's OK, the battery's fully charged with all the connections clean and tight, then it has to be the starter motor or engine. Check you can turn the engine by hand, if so then I would guess, it's probably the starter motor.
Good Luck
Apr 21, 2013 | Husqvarna Garden
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
My lawn mower won't start.
pour a little gas in carb then pull rope see if it starts or starting fluid
Jun 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Can you tell me why the optoma HD72I lamp will turn off after just a few minutes of running, the lamp is still fine
I have the same problem. I got a new bulb and it worked for about 1000 hours, then the new bulb started having the same problem. So, I was about to buy another bulb, and I figured why not try the original bulb. IT WORKED! For a couple weeks... Then it started doing it again. Obviously there was nothing wrong with the original bulb, and there is nothing wrong with the new bulb, but I have 2 bulbs that do it now. So, is there any way to just tell the projector run the bulb till it actually dies and not turn it off because it thinks it is about to die.
Aug 01, 2008 | Optoma HD72 Multimedia Projector
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
202 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
