Question about Xerox WorkCentre Pro 90 Copier
Xerox workcentre pro 90 says tray 2 not available, reset software and hardware but wont print from tray 2, paper size 11x17, any ideas
  • 33 Answers
Take the paper tray out as follows: open the front door, pull the tray out as far as it goes. On the side rails there is a hole and if you look into the hole there is a stopper. Turn this stopper a little by a small screw driver or similar and simultaneously pull the tray out on the other side, then the remaining side one by one.
On the back side of the tray there is a sector plastic gear and a smaller one. Sometimes they lose teeth because paperr stack is very heavy and thy are made of plastic.
Another cause may be improperly installed feed rollers.They must be installed right way round. When paper stack raises the feed rollers actuate a fork which, in turn, actuates a plastic flag which in turn blocks a sensor in the inside back wall if the copier/printer. Everything is fu**ing plastic and breaks easily.
Posted on Sep 08, 2010
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Hi - I have a Xerox Workcentre 4250 Printer/Fax and keep getting error code 22-504 (Paper Properties Mismatch). The tray has the correct paper size ... what to do? All the pending jobs are idle ...
Check the print settings on the documents that are idle; they may be an off size rather than the standard and you may have to fake out the printer by "resetting" the paper size to the size of the print jobs; this sounds off but works in may cases. To reset the papersize, pull out the tray and put it back in, manually set the page to whatever it is calling for.
Please let me know if this is not clear,
Good Luck!
Oct 07, 2010 | Xerox WorkCentre M-24 Color Copier
M20/Ms0i WorkCentre display "Paper Size Mismatch"
the settings on the print driver and the machine do not match.
  1. ress the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required paper tray is displayed; either [Tray 1 Size], [Tray 2 Size], or [Bypass Size].
  4. Press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until the paper size loaded in the paper tray is displayed.
  6. Press the [Enter] button to save the setting.
  7. Press the [Stop] button to return to the Standby mode.
Jan 28, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
165 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
