I have a Benq Q7C4 and the VGA input does not appear to be working the DVI input works fine.
  • irenesmober Apr 30, 2009
    when i switch it on, it appears the benQ logo, but after 1 sec the display gets black and stays black!
  • 207 Answers
SOURCE: no video input, just crashed msg 'dvi
Possible!!! try to reseat your video card.maybe this will help..
if it doesn't work..let me know..
Posted on Jan 25, 2008
  • 164 Answers
SOURCE: DVI no input signal......VGA input active.
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Posted on Feb 22, 2009
  • 263 Answers
SOURCE: my monitor will not work with the originally
Try this if you haven't already, UNPLUG THE MONITOR FROM THE WALL.
Alternatively try another dvi cable could be a dodgy cable.
Posted on Aug 01, 2009
  • 345 Answers
SOURCE: monitor shows VGA no input signal DVI no input
This sounds like a video card driver issue or the card it self. Make sure all cables are plugged in snug. Once done try to boot in to safe mode by restarting the computer and while it is starting keep on tapping key F8 and choose safe mode. If this works it is driver issue. If nothing happens it is the card it self. Might have to take it to a authorized repair shop. Hope this helps.
Posted on Feb 15, 2010
  • 19 Answers
SOURCE: i have HP Pro3000MT, and
you need a dvi to vga adapter not a dvi to vga plug and you must also go into your graphics card setup catalyst control center if its ATI Nvidia Display manager for Nvidia if you boot the computer with it pluged in and you can see the boot screen on bolth displays then its an os thing just right click and select the display manager the activate all display's through the managers
Posted on Apr 02, 2011
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
Benq q7c4
have you tryed to unplug vga cord and powerd cord with your computer turned on? you get some image, does it turn off after that?
May 28, 2013 | Computers & Internet
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Dvi input problems
Hi 1ivans
I would suggest that you should firstly try another DVI cable.
If this doesn't work , then the comms board will most probably need replacement.
Apr 27, 2008 | BenQ PE8700 Multimedia Projector
Benq fp737 17
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Nov 28, 2007 | BenQ FP731 17" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Computers & Internet Logo
880 people viewed this question
David Payne
David Payne
