Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
Rotating shaft will not rotate - during the kneading process nothing happens
  • 433 Answers
1) Make sure bread pan is inserted in the machine correctly. 2) Take pan out of the machine and make sure the paddle spins freely on the shaft. ( If not, sealed bearing is frozen and pan needs to be replaced. 3) Keep pan out of machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not the belt may have come off , snapped or there is something wrong with the motor or curcit board in the machine . Hank
Posted on Aug 25, 2010
The kneading machansm ell not rotate
If you remove the pan and reach underneath it and grab the little" ears" and try to turn them does the shaft rotate?
Dec 31, 2012 | Welbilt ABM3500 Bread Maker
The top bar on the inside that holds the racks has stopped spinning during bake.
The top bar, referred to as the "carrier" will only rotate when you start your bake cycle. If there is an issue with the rotation you should hear a steady buzzer about once every second. If you are hearing the buzzer that means the rack alignment switch isn't closing momentarily during rotation like it should be. This could be a result of a number of things, such as a bad rack switch, mis-adjusted rack switch, burned or broken wire on rack switch, bad rotation motor, rotation motor chain or sprockets fell off or are loose, or the shaft switch bar is loose (unlikely).
If you are NOT hearing the beeping then the carrier inside the oven itself could have some loose set screws and the shaft could be spinning freely inside the carrier.
Look on top of the oven and you will see a rectangular shield covering the lift and rotation assembly, remove these covers and verify if the shaft is spinning and hitting the little switch mounted near the top of the shaft.
Mar 01, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I have an old toastmaster bread machine model 1154, and I realized that the kneading blade does not rotate when the ingredients are in the bread pan. Either the kneading blade mounting shaft and the...
If the spindle is turning and the paddle is not then your paddle is worn out and probable slipping on the spindle. If the spindle isn't turning then your problem is underneath the pan or inside the drive and your paddle may be fine.
Dec 01, 2010 | Toastmaster Kitchen Appliances - Others
The drive shaft is no longer rotating. it stopped mid knead.
Hi, Take the pan out of the machine and see if you can spin the paddle freely by hand. If yes, that's great. If it's sticking and not turning freely then the sealed bearing may be frozen and failing. Next, keep the pan out of the machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not, then the belt either fell off, is loose, or has snapped. Motor and belts are located in the base of the machine. Be sure to unplug machine before you check that. Hank
Sep 22, 2010 | Regal Ware K6725 Kitchen Pro Bread Maker
It seems the motor on my Breadman Ultimate 2200C has burned out.
If the motor shaft is not spinning with the bread pan out of the machine it could be the belt has fallen off the pulley, or has snapped. The belt and pulley are inside the base of the machine. Hank
Jan 21, 2010 | Breadman TR2200C Ultimate Bread Maker
When i put the ingredients as directed, i selected the program then put the delay on. when i woke up expecting fresh bread, i had a hard 3 inch brick with flour and yeast sitting on top of it. was i...
No, Everything should be done automatically. It seems that the machine did not knead the dough. Two things may have caused this. 1) The paddle is frozen and wont turn. Take the pan out of the machine and see if you can rotate the paddle by hand. If yes...that's cool, if no then the sealed bearing that the paddle rotates on is jammed or broken. Try filling the pan with warm water and let it soak. If after a few times it's still frozen, then the bearing is broken and bread pan needs to be replaced. 2) Belt fell off or is snapped. Keep the pan out of the machine and go to a kneading cycle. Look through the window on the lid and see if the motor shaft is turning. If no... the belt fell off or snapped, or the motor is broken. Good luck..Hank
Dec 03, 2009 | Oster 5836 ExpressBake Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
Bread pan pops out during kneading, hard to remove after baking
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Feb 22, 2009 | Breadman TR2200C Ultimate Bread Maker
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
372 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
