Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not start. timer will not advance - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • 6,784 Answers
HI. In most cases, this will be a failed timer motor. Use my procedure below to isolate the timer and replace it, if needed. Timer Testing procedure; Lift the top control panel up and take a close look at the timer motor control. Depending on your make and model, there may be a number of wires connected to it. Locate the wires that deliver power to the mechanism. These wires should be slightly larger in size than the other ones. Use your needle nose pliers to remove one of the power leads. Pull the connector off the terminal by pulling on the connector, NOT the wire, or it may break the wire. Lift the washers control panel up and set your units timer to a normal wash cycle. If your multimeter came with alligator clip probe adapters, this will be handy here, so put them on if you have them. If not, any meter(ohm) will do. Set the multimeter to read ohms (usually labeled R1 or RX1). Clip or touch one probe to the terminal from which you removed the wire. Touch the other probe to one of the other terminals. You should get a reading of zero. If you get a high reading, then the timer motor is bad and it's time to replace it.
Posted on Aug 24, 2010
  • Michael Masters
    Michael Masters Aug 24, 2010
    • NOTE_ If the timer passes its respective test; Replace the lid switch assembly.
Sears kenmore dryer timer not advancing, replaced still won't advance, what could be wrong?
It sounds like the timer motor (attached to the back of the timer assembly) is not getting power. Possibly, the timer wiring connector is not making good contact or the timer wiring harness has been damaged.
Also, make sure that both 120 volt phases (240 volts between the two phases) are energized to the main power cord.
Apr 02, 2017 | Kenmore Dryers
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Reset on mat14PDAWW
NOTE: On some models, during factory testing, the timer is
advanced partially into the cycle causing the start button to be
depressed. Allow timer to advance to the end of the cycle.
When the cycle is complete, the timer will reset and the start
button will return to the start position. If the timer is not allowed
to advance to the end of the first cycle and reset, the wash load
will not be completed. here is the manual
Download manual
Jan 10, 2015 | Maytag Washing Machines
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Programing
You posted under Leviton 6124 programmable timer.
If this is not your timer, add a comment
Leviton 6124 manual:
http://waterheatertimer.org/images/6124-manual.pdf
If you have different timer, look at link below to help identify timer.
Leviton Timers:
http://waterheatertimer.org/Leviton-timers.html
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Dec 02, 2010 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Decora 6124H Timer
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Hotpoint Aquarius TDL30 tumble dryer timer not advancing
fmw76:
This could be a timer issue or a thermostat.
If you are using a timed dry it would be timer .
If you are using an auto dry cycle it would possibly be a thermostat.
woodychoppers
Nov 01, 2008 | Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
